When i setup nmba the only router that works with the designated router is router 2. But when i set all routers to broadcast mode then all of then show dynamic routes.
Yes, all OSPF packets are sent with TTL 1, even in NBMA networks, so all OSPF neighbors must be directly connected (excluding neighbors on virtual-links and sham-links).
On the other hand, in NBMA networks you need to have direct connection between two OSPF routers only if either of them is a DR or a BDR. Between two routers in DR-Other state connectivity is not necessary.
