NMP-8602 Problems
Dear All,
Last week , i bought rb532a with 2 NMP-8602 cards …
I am facing a problem , It was setup as AP Bridge .. Most of time we can see the SSID as 76% but we can’t ping the station also there is no internet ..
Note : we can see it from the LAN card .. another problem is that we are facing another problem , there is a delay with the time between the station and the client .
I hope you can help me with this because it is urgent !
Thank you
Ghassan
But I really want to know why do i have many problems .I want to see a stable ping .. Is it from the Wireless Card NMP-8602+ (rb532a).. Most of time I can see its SSID but with no internet connection .. with high ping delay starting from 800 to 3000ms .
What is wrong ?
I already changed pigtales , sectors , antennas !!
Thank you.
Notice that I shall disable the interface many times and enable it so I can establish a connection with clients , also I already tried to chnage the wireless card and I have failed , the same results .
And once again my posts are deleted because they reference MT’s shortcomings.
It’s sounds like you are using prisim based clients. Switch out the radio card to a NMP-2511 card and it should fix the problem.
We have more than 40 AP Clients .. every 3 seconds I can see about every 3 seconds more than 10 access points disconnecting then connecting …
Our clients are using D-link 2100 as a client ..
Yep, it’s a well know problem that MT denies. They also repeatedly delete any posts relating to it.
The only solution that has been found that actually works is to replace the radio with the older 2511 card or switch to all Atheros based clients.
notice that I have a delay with the time , it seems that I am facing such interference , I ran Snooper and I noticed that my SSID is getting almost 100% of traffic with bandwidth 227K why ?
