I just went thru and changed all clients connected to a given AP to a 10 MHZ bandwidth only to discover the netbox 5 won’t allow a 10 MHZ or 5MHZ bandwidth in AP bridge mode. Setup is 802.11 , ap bridge , no-country-code .
Ok , I pulled another netbox out of inventory and checked it’s settings and found the 10 mhz band accessible . If I try on the original unit , no matter the country code , as soon as I select 10mhz from the drop down , the channel goes to auto with no other option. Seems I have a flaky unit.
Then you found a Basebox, not a Netbox, all Mikrotik AC Hardware is missing:
- Advanced Channels (5/10/30) MHz
- Spectral Scan
The model header says Netbox 5.
