Hello. I have a problem with 2GHz WiFi. The connection in N. doesn’t work. It only connects in G despite the G / N setting. The board is RB433GL, card R52nM.
name="Test2GHz" mtu=1480 l2mtu=1600 mac-address=D4:CA:6D:xx:xx:xx
arp=enabled interface-type=Atheros AR92xx mode=ap-bridge ssid="Test2GHz"
frequency=2447 band=2ghz-g/n channel-width=20/40mhz-XX
secondary-channel="" scan-list=default wireless-protocol=any
vlan-mode=no-tag vlan-id=1 wds-mode=disabled wds-default-bridge=none
wds-ignore-ssid=no bridge-mode=enabled default-authentication=yes
default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0
hide-ssid=no security-profile=WPA2 compression=no
I use RouterOS v 6.45.3
