No 802.3ad response from the link partner for any adapters in the bond - HAP AX3
Hi all, I have just got the HAP AX3 recently, but I am struggling establishing a LACP connection to my proxmox server. In my journalctl I get the warning:
I have followed a couple of tutorials online for both Mikrotik and Proxmox, but it doesn’t seem to work properly and I can’t make any sense of it.
I can:
ping the proxmox host from my pc in the same network
ping the proxmox host from my router
ping my computer from the proxmox host
access internet from a VM hosted on the proxmox host (dhcp)
ping the forementioned VM from my computer
I can’t:
ping the router from the proxmox host
ping the router from any proxmox container on the proxmox host (static ip 10.0.0.containerID e.g. 10.0.0.103)
ping any of the proxmox containers from my computer
Following are:
/etc/network/interfaces
# network interface settings; autogenerated
# Please do NOT modify this file directly, unless you know what
# you're doing.
# If you want to manage parts of the network configuration manually,
# please utilize the 'source' or 'source-directory' directives to do
# so.
# PVE will preserve these directives, but will NOT read its network
# configuration from sourced files, so do not attempt to move any of
# the PVE managed interfaces into external files!
auto lo
iface lo inet loopback
auto enp10s0
iface enp10s0 inet manual
auto enp9s0
iface enp9s0 inet manual
auto bond0
iface bond0 inet manual
        bond-slaves enp10s0 enp9s0
        bond-miimon 100
        bond-mode 802.3ad
        bond-xmit-hash-policy layer2+3
auto vmbr0
iface vmbr0 inet static
        address 10.0.0.100/24
        gateway 10.0.0.1
        bridge-ports bond0
        bridge-stp off
        bridge-fd 0
and mikrotik setup:
# 2023-08-27 19:23:09 by RouterOS 7.11
# software id = 8U7C-8YHW
# model = C53UiG+5HPaxD2HPaxD
# serial number =
/disk
set usb1 type=hardware
add admin-mac=48:A9:8A:E2:86:FF auto-mac=no comment=defconf name=bridge
/interface wifiwave2
set [ find default-name=wifi1 ] channel.skip-dfs-channels=10min-cac \
    configuration.country="United States" .mode=ap .ssid=\
    "the owls are not what they seem" disabled=no \
    security.authentication-types=wpa2-psk,wpa3-psk
set [ find default-name=wifi2 ] channel.skip-dfs-channels=10min-cac \
    configuration.country="United States" .mode=ap .ssid=legacy disabled=no \
/interface bonding
add mode=802.3ad name=bonding1 slaves=ether4,ether5 transmit-hash-policy=\
    layer-2-and-3
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=10.0.0.10-10.0.0.100
add address-pool=dhcp interface=bridge lease-time=10m name=defconf
add bridge=bridge comment=defconf interface=wifi1
add bridge=bridge interface=wifi2
add bridge=bridge interface=bonding1
/interface detect-internet
set detect-interface-list=WAN internet-interface-list=WAN lan-interface-list=\
    WAN wan-interface-list=WAN
add address=10.0.0.1/24 comment=defconf interface=bridge network=10.0.0.0
add address=10.0.0.100/24 interface=bonding1 network=10.0.0.0
/ip dhcp-client
add address=10.0.0.0/24 comment=defconf dns-server=10.0.0.1 gateway=10.0.0.1 \
    netmask=24
set allow-remote-requests=yes servers=1.1.1.1,1.0.0.1
/ip dns static
add address=10.0.0.1 comment=defconf name=router.lan
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    established,related,untracked
    connection-state=invalid
/ip service
set telnet disabled=yes
set ftp disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/ip traffic-flow
set interfaces=bonding1
/ip upnp interfaces
add interface=bridge type=internal
add interface=ether1 type=external
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
    33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/system clock
set time-zone-name=America/Los_Angeles
/system note
set show-at-login=no
Thank you in advance for any help!
Hi!
auto bond0
        bond-primary enp10s0
        bond-miimon 100
        bond-mode 802.3ad
Can you check the contents of the following?
cat /proc/net/bonding/bond0
Even if you get links, this Mikrotik device doesn’t have a “real-switch chip” - so the aggregated link is limited by CPU power on the Mikrotik device.
( This means, you bonding 2x1G link, but you wont able to achive this bandwidth or even worse when using just simple 1x1G link. )
https://help.mikrotik.com/docs/display/ROS/Bridging+and+Switching#BridgingandSwitching-BridgeHardwareOffloading
→ IPQ-PPE
Sorry you mean that with HAP AX3’s IPQ-PPE chip is discouraged bonding two 1Gbps ports as we will get worse performance?
Actually I created a bonding to a TrueNAS Scale server and I think I get worse transfer speed than the simple direct connection…
Considering the bond is over VLAN, is it possibile that I’m getting a CPU bottleneck?
