Hi, new to Mikrotik and I have a LTE router with Hap Ac Lite and I have a big issue straight away that I dont have any access to the internet, Netflix etc.
I dont have much experience in knowing what to do so im hoping you guys can get me out of a pickle!
Thank you for uploading the configuration. Without it, we’re guessing…
For future reference, when uploading click the code display icon in the toolbar above the text entry (the code display icon is the 7th one from the left and looks like a square with a blob in the middle). Then paste the text from the file in between the two code words in brackets. Makes it easier to deal with on the forum.
That’s a really straight forward config…
Confirm that the LTE “router” is connected to port 1 of the hAP via a cable, and you are plugging in the computer you are using for test into any other port on the hAP? The test computer should be set for DHCP and should therefore get an IP address in the 192.168.88.x range. If all this is true, you should be able to communicate with the hAP via IP address 192.168.88.1
Since you were able to capture the config of the hAP, I am assuming for the moment that the hAP is getting an IP address on port 1 (being used as the WAN port). Can you confirm if the hAP is getting an IP address on the WAN interface (port 1)? If yes, can try tools on the hAP and try to ping 8.8.8.8. Do you get a response?
Are you using WinBox, WebFig, or a text based command port to communicate with the hAP?
Hi, yes connections to the Hap are correct in the way you said.
I was only able to post the terminal script by using a hotspot on my phone, however for some reason I can now connect through my Hap using the IP address 192.168.1.1 but before I was only able to access the LTE via IP address 192.168.88.1…but now I can’t access the LTE address.
My suggestion for using a cable rather than a WiFi connection is it is a known and eliminates the WiFi as being part of the problem…
That statement is confusing. Almost sounds like you were connecting via WiFi to the LTE router and not the hAP. What is the LTE router, and how is it configured?
I was assuming it was operating essentially as a cellular modem and providing a wired internet connection to the hAP. Sounds like there is more to it.
right essentially what I’ve done is left an ISP who had pre-configured my Mikrotik equipment the LTE and the Hap and I’ve since left them and now have a cheaper tariff using a SIM only deal.
What they told me to do was to factory reset the Hap and that has since wiped out the previous configurations and I’m left in this mess so that’s the situation I’m at and I’m at a loss of what to do hence being new to the Mikrotik world, hope that makes sense.
I’ve got to run, but it sounds like the LTE router is another Mikrotik and it is also trying to have a LAN address range of 192.168.1.n. Therefore, the WAN side of hAP and the LAN side of the hAP are both in the same address range - which will not work right. Are you trying to use the hAP just as a switch and leave all the router functions in the LTE router, or leave teh LTE router as dumb as you can make it and use the hAP for all your “router” functions?
And what is the LTE router?
Hi, yes the LTE is also a Mikrotik brand and its purpose is to give the best possible signal and its located externally and the purpose of the Hap is to act as the router.
How do I go about configuring in the way its meant to do its job correctly without both devices conflicting the IP addresses?
If LTE is simply passing a public IP to the hapac, shouldnt be conflict.
More likely LTE is getting the public IP and then through its LAN passing the traffic to the HAPAC.
The problem is the HAPAC probably has the same LAN IP subnet as the LTE,
So k6ccc is stating change the default LANIP structure on either of the two MT devices to something else.
You have to do the work LOL, its the only way to learn the router.
What i suggest is you take an unused port on the hapac ether X.
assign 192.168.55.1/24 IP address to it
ensure you add it ( the ether port ) to the Interface list of LAN
ensure you remove it ( the ether port ) off the bridge.
plug your laptop into ether X and put ipv4 settings of 192.168.55.5 for example, 255.255.255.0 gateway 192.168.55.1 DNS server 192.168.55.1
And you should be able to login into winbox.
Then you can play with changing the settings of the bridge without fear of locking yourself out.
Will take some steps.
but mainly
(1) change the IP pool of the bridge first
from 192.168.88.XX - 192.168.88.YYY (to your new subnet)
To: 10.10.88.XX - 10.10.88.YYY
(2) change the IP address assigned to the lan to 10.10.88.1/24
(3) DHCP server ( should require no change )
(4) change the dhcp server-NETWORK to 10.10.88.0/24 gateway 10.10.88.1 and dns-server 10.10.88.1
That should be close to see if you have a better experience with the two devices interacting…
The advice provided was that likely you had the same LAN subnet on both devices and therefore there would be conflict.
Tell us what you attempted, because we have no clue to what you had, what you changed and what you want to do???
