i work with lv6 MT license and the package..
i’m using static client (with ip and mac address) with the user for purpose running the hotspot..
so i list the clients of my network in the ip hotspot with their password etc..then i activate User Manager with this procedure :
- add Router IP address and secret to ‘Routers’ menu in User Manager.
- enable RADIUS client to communicate with User Manager server.
- create users at ‘Users’ menu in User Manager.
- force HotSpot to use RADIUS for AAA, ‘ip hotspot profile set default user-radius=yes’. (Note, local database is consulted first, than remote RADIUS database).
User Manager contains many options, but there is described basic example, how to enable communication between HotSpot router and User Manager.
then..the hotspot is running well..but when i check the UM it shows no active session and no report with the current connection..
Did i missing something here?
how should i do to communicate ip-hotspot with UM?
really need your help..
thank you..
and i see in the /log it says : “login failed: RADIUS server is not responding”…
ok..
then..
am i correct to use hotspot address=MT router address=/radius server address?
am i have to force it till it succed to communicate with UM?
thanks to Mr. Hasbullah…i apreciate so much for your quick response
at this link my hotspot config: Problem regarding running hotspot on CHAP and PAP - #3 by balimore - MikroTik hardware general - MikroTik community forum
yes, you are able comuni..with userman web interface, than add user form it web. don't use local hotspot users in user-list
i have tried many times to force my hotspot to radisu server...but it still don't work out..
i'm near to desperate right now...
what should i do??
i'm using RouterOS address: 192.168.6.254
this is my config :
[*******@MikroTik] ip hotspot profile> print
Flags: * - default
0 * name="default" hotspot-address=192.168.6.254 dns-name="hotspot.info"
html-directory=hotspot/img rate-limit="0/0" http-proxy=0.0.0.0:0
smtp-server=0.0.0.0 login-by=mac,http-chap,https,http-pap
ssl-certificate=none split-user-domain=no use-radius=yes
radius-accounting=yes radius-interim-update=2m30s nas-port-type=ethernet
radius-default-domain="radhot" radius-location-id=""
radius-location-name=""
Flags: * - default
0 * name="default" address-pool=kost idle-timeout=none keepalive-timeout=1m30s
status-autorefresh=30s shared-users=1 transparent-proxy=yes
open-status-page=http-login advertise=yes advertise-timeout=1m
Flags: X - disabled
SERVICE CALLED-ID DOMAIN ADDRESS SECRET
0 ppp 192.168.6.254 ******
login
hotspot
