I have a 2.4GHz CPE located inside a building where my tower is located – i.e., distance is not a problem. Every so often, it goes into disconnect fits:
10:11:20 wireless,debug wwan-ptp: must select network
10:11:20 wireless,debug 4C:5E:0C:11:43:26: on 2452 AP: yes SSID AirJohnson caps 0x431 rates 0xff0f basic 0xf MT: yes
10:11:20 wireless,debug 00:0C:42:6C:1B:17: on 2427 AP: yes SSID Call-623-640-7883(RV) caps 0x431 rates 0xff0f basic 0x101 MT: yes
10:11:20 wireless,debug 00:0C:42:BA:E7:7F: on 2417 AP: no SSID Call-623-640-7883(MK) caps 0x0 rates 0x0 basic 0x0 MT: no
10:11:20 wireless,debug 54:A0:50:EE:D2:D4: on 2462 AP: yes SSID Home caps 0x411 rates 0xff0f basic 0xf MT: no
10:11:20 wireless,debug wwan-ptp: 4C:5E:0C:11:43:26 uses regular 802.11, skip
10:11:20 wireless,debug wwan-ptp: 00:0C:42:6C:1B:17 uses regular 802.11, skip
10:11:20 wireless,debug wwan-ptp: 54:A0:50:EE:D2:D4 uses regular 802.11, skip
10:11:20 wireless,debug wwan-ptp: 00:0C:42:BA:E7:7F not allowed by connect-list
10:11:20 wireless,debug wwan-ptp: no network that satisfies connect-list, by default do not connect
10:11:20 wireless,debug wwan-ptp: 00:0C:42:BA:E7:7F uses TDMA, skip
10:11:20 wireless,debug wwan-ptp: 54:A0:50:EE:D2:D4 does not support short preamble, skip
10:11:20 wireless,info 00:0C:42:6C:1B:17@wwan-ptp established connection on 2427000, SSID Call-623-640-7883(RV)
10:11:22 wireless,info 00:0C:42:6C:1B:17@wwan-ptp: lost connection, no beacons received
10:11:25 wireless,debug wwan-ptp: must select network
10:11:25 wireless,debug 4C:5E:0C:11:43:26: on 2452 AP: yes SSID AirJohnson caps 0x431 rates 0xff0f basic 0xf MT: yes
10:11:25 wireless,debug 00:0C:42:6C:1B:17: on 2427 AP: yes SSID Call-623-640-7883(RV) caps 0x431 rates 0xff0f basic 0x101 MT: yes
10:11:25 wireless,debug 00:0C:42:BA:E7:7F: on 2417 AP: no SSID Call-623-640-7883(MK) caps 0x0 rates 0x0 basic 0x0 MT: no
10:11:25 wireless,debug 54:A0:50:EE:D2:D4: on 2462 AP: yes SSID Home caps 0x411 rates 0xff0f basic 0xf MT: no
10:11:25 wireless,debug wwan-ptp: 4C:5E:0C:11:43:26 uses regular 802.11, skip
10:11:25 wireless,debug wwan-ptp: 00:0C:42:6C:1B:17 uses regular 802.11, skip
10:11:25 wireless,debug wwan-ptp: 54:A0:50:EE:D2:D4 uses regular 802.11, skip
10:11:25 wireless,debug wwan-ptp: 00:0C:42:BA:E7:7F not allowed by connect-list
10:11:25 wireless,debug wwan-ptp: no network that satisfies connect-list, by default do not connect
10:11:25 wireless,debug wwan-ptp: 00:0C:42:BA:E7:7F uses TDMA, skip
10:11:25 wireless,debug wwan-ptp: 54:A0:50:EE:D2:D4 does not support short preamble, skip
10:11:25 wireless,info 00:0C:42:6C:1B:17@wwan-ptp established connection on 2427000, SSID Call-623-640-7883(RV)
10:11:27 wireless,info 00:0C:42:6C:1B:17@wwan-ptp: lost connection, no beacons received
10:11:30 wireless,debug wwan-ptp: must select network
[/size]
When it is connected, it shows a signal of -57/-62 and CCQ of 70/94% from the CPE side, with S/N 48dB, so again, this is not a signal problem. The only odd thing about this CPE is that it is a “relay” unit (AirJohnson is a 2.4GHz AP in the same case) but the frequencies are separated. There are no other signal sources nearby on the same frequencies. The “MK” tower, which is close in frequency, is about a mile distant, and “Home” is some neighbor’s WiFi unit.
This morning, the fit lasted 12 minutes, and caused the tower to virtually lock up for other users.
None of the controls in /int wireless seem to control connection retry time, only packet retry time.
What can be done about this?
