No beeper on some Routerboards
I found out that there is no beeper on some Routerboards. :open_mouth:
I trashed a bunch of RB750G routers when I found out that the beeper is missing. :smiling_imp:
You seriously trashed them?! I would have gladly taken them off your hands.
Seriously, no I’m not insane (not yet). :slight_smile:
A word of warning, don’t cheap out like I did. For $30 more, you’ll get these features if you buy RB450G:
RB450G
  1. 256MB RAM
  2. MicroSD card slot
  3. RS232C Port
  4. Temperatur Sensor
  5. Voltage Monitor
  6. Level 5 license
  7. Beeper
RB750G
  1. 32MB RAM
  2. No MicroSD card slot
  3. No RS232C Port
  4. No Temperatur Sensor
  5. No Voltage Monitor (not working)
  6. Level 4 license
  7. No Beeper
Okey, I purchased RB750G instead of RB450G, so I’m insane. :frowning:
It doesn’t say anywhere that the RB750G has a beeper. Why do you need a beeper anyway?
I use the beeper as alarm, it’s very useful. :slight_smile:
Don’t forget another $15 or so for case and power supply + labor for putting it together.
When buying a few hundred units the difference really adds up.
