no communication between 2 wan
Hi, I use a translator since I don’t speak much English, I have a problem with my rb4011
I have 2 wan, I have 6 vlans,
in wan1 it has the traffic of 3 vlans directed, and wan2 with the other 3 vlan,
The problem is that I do not have communication with the vlans of the wan2, but the wan1 does work
I can access the computers of wan1, but I do not have access to wan2, when I deactivate the mangle rule that directs traffic through wan2, it gives me access to the network, open a solution so that I continue to have access to the computers of wan2 and to be able to divide the traffic by the wan that I select
Hola, uso un traductor ya que no hablo mucho ingles, tengo un problema con mi rb4011
tengo 2 wan, tengo 6 vlans,
en la wan1 tiene dirigido el trafico de 3 vlans, y la wan2 con las otras 3 vlan,
El problema es que no tengo comunicación con las vlans de la wan2, pero la wan1 si funciona
puedo acceder a los equipos de la wan1, pero la wan2 no tengo acceso, cuando desactivo la regla mangle que dirige el trafico por la wan2, me da acceso a la red, abra alguna solución para que siga teniendo acceso a los equipos de la wan2 y poder dividir el trafico por la wan que yo seleccione
Please provide a diagram of your network.
Understand vlans x, y, z are to use WAN1
Understand vlans a,b,c are to use WAN2
When you say you cannot access the vlans do you mean:
a. FROM EXTERNAL WAN location
b. From VLAN x to vlans a, b, c
c. FROM VLAN a to vlans x, y, z
ALSO Please post your config
/export hide-sensitive file=any_name_you_wish
