I tried to load a backup on my hAP ac², but picked a backup file of a hAP lite. After that Winbox did no longer find the Router.
So I tried a netinstall that seemed to work:
sudo ./netinstall -a 192.168.1.3 routeros-arm-6.48.3.npk
Using server IP: 192.168.1.2
Starting PXE server
Waiting for RouterBOARD...
PXE client: B8:69:F4:4D:3B:3D
Sending image: arm
Discovered RouterBOARD...
Formatting...
Sending package routeros-arm-6.48.3.npk ...
Ready for reboot...
Sent reboot command
After reboot Ethernet 1 seems to stay down, on the Router and the attached switch the port LEDs don’t indicate a attached device. the other Ethernet ports show on router ans switch port LEDs on, but no detection/connection via winbox possible.
Netinstall still works in Ethernet 1 with showing the indicator LEDs on Router and switch until reboot.
Would be great if anyone could help.
