Hi all, as the title implies, when setting up a cap on CAPsMAN, I get an error message “no connection to CAPsMAN” I’m not sure if there is a firewall rule that might be blocking the traffic? I can ping the CapsMan router from the cap and visa versa. I’m at my ends here.
The Caps are directly connected to the router, from ether3-ether6
Any help would be greatly appreciated.
Router Config
# 2024-09-25 13:22:43 by RouterOS 7.15.3
# software id = 7UAI-U0HI
# model = RB5009UG+S+
# serial number =
/caps-man channel
add band=2ghz-b/g/n control-channel-width=20mhz extension-channel=disabled \
frequency=2412 name=2412 secondary-frequency=disabled tx-power=14
frequency=2437 name=2437 secondary-frequency=disabled tx-power=14
frequency=2462 name=2462 secondary-frequency=disabled tx-power=14
add band=5ghz-onlyac control-channel-width=20mhz extension-channel=XX name=\
5Ghz reselect-interval=1h save-selected=yes skip-dfs-channels=no \
tx-power=20
add band=2ghz-onlyn control-channel-width=20mhz extension-channel=disabled \
frequency=2412,2437,2462 name=2.4Ghz secondary-frequency=disabled \
tx-power=14
add arp=proxy-arp name=Bridge-LAN
set [ find default-name=ether1 ] arp=proxy-arp name=ether1-WAN
set [ find default-name=ether2 ] name=ether2-LAN
set [ find default-name=ether3 ] name="ether3-Admin AP"
set [ find default-name=ether4 ] name="ether4-Hallway AP"
set [ find default-name=ether5 ] name="ether5-Blue AP"
set [ find default-name=ether6 ] name="ether6-Green_Orange AP"
set [ find default-name=ether8 ] name="ether8 - LTE Fail Over"
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1-WAN name=\
"Internet In-Web Africa" use-peer-dns=yes user=********
/interface wireguard
add listen-port=13231 mtu=1450 name=Pepla_WG
/caps-man datapath
add bridge=Bridge-LAN client-to-client-forwarding=no local-forwarding=yes \
name=Internet
/caps-man security
add authentication-types=wpa2-psk encryption=aes-ccm group-encryption=aes-ccm \
group-key-update=40m name="WiFi Security"
/caps-man configuration
add channel=2.4Ghz channel.frequency=2412,2437,2462 country="south africa" \
datapath=Internet datapath.bridge=Bridge-LAN installation=indoor mode=ap \
name="Config 2.4Ghz" rx-chains=0,1 security="WiFi Security" ssid=Pepla \
tx-chains=0,1
add channel=5Ghz country="south africa" datapath=Internet datapath.bridge=\
Bridge-LAN installation=indoor mode=ap name="Config 5Ghz" rx-chains=0,1 \
security="WiFi Security" ssid="Pepla 5G" tx-chains=0,1
add name=LAN
add name=WAN
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=sha512
add name=DHCP-LAN ranges=192.168.0.11-192.168.0.239
add address-pool=DHCP-LAN interface=Bridge-LAN lease-time=2d name=DHCP
/routing table
add comment="Table for WireGuard - JPB" disabled=no fib name=WG-Pepla
/caps-man access-list
add action=accept allow-signal-out-of-range=10s disabled=yes signal-range=\
-85..120 ssid-regexp=""
add action=reject allow-signal-out-of-range=10s disabled=yes signal-range=\
-120..-86 ssid-regexp=""
/caps-man manager
set ca-certificate=auto certificate=auto enabled=yes
/caps-man provisioning
add action=create-dynamic-enabled master-configuration="Config 2.4Ghz" \
name-format=identity
add action=create-dynamic-enabled master-configuration="Config 5Ghz" \
add bridge=Bridge-LAN interface="ether3-Admin AP"
add bridge=Bridge-LAN interface="ether4-Hallway AP"
add bridge=Bridge-LAN interface="ether5-Blue AP"
add bridge=Bridge-LAN interface="ether6-Green_Orange AP"
add bridge=Bridge-LAN interface=ether2-LAN
set enabled=yes udp-timeout=10s
/interface l2tp-server server
set default-profile=default use-ipsec=yes
add interface=Bridge-LAN list=LAN
add interface="Internet In-Web Africa" list=WAN
/interface wireguard peers
add allowed-address=192.168.89.3/32 client-dns=192.168.0.1 interface=Pepla_WG \
name="user1" persistent-keepalive=30s private-key=\
"******************* public-key=\
add allowed-address=192.168.89.2/32 client-dns=8.8.8.8 interface=Pepla_WG \
name="user2" persistent-keepalive=30s private-key=\
"*******************" public-key=\
add allowed-address=192.168.89.4/32 interface=Pepla_WG name="User3" \
add allowed-address=192.168.89.5/32 interface=Pepla_WG name="User4" \
add allowed-address=192.168.0.6/32 interface=Pepla_WG name=\
"User5" persistent-keepalive=30s private-key=\
add address=192.168.0.1/24 interface=Bridge-LAN network=192.168.0.0
add address=41.132.65.127 disabled=yes interface="Internet In-Web Africa" \
network=168.210.4.66
add address=192.168.89.1/24 comment=Pepla_WG interface=Pepla_WG network=\
192.168.89.0
add address=192.168.0.0/24 dns-server=192.168.0.1 gateway=192.168.0.1 \
ntp-server=154.73.32.1,154.73.32.2
set allow-remote-requests=yes servers=192.168.0.1
/ip firewall address-list
add address=154.73.32.0/22 disabled=yes list=iewc-ip4s
add address=165.16.200.0/21 disabled=yes list=iewc-ip4s
add address=192.168.0.0/24 disabled=yes list=MGMT-RANGES
add address=192.168.88.0/24 disabled=yes list=MGMT-RANGES
add address=192.168.0.0/24 list=Local-LAN
add address=192.168.89.0/24 list="WIRE GUARD"
"Allow: Established, Related, Untracked" connection-state=\
established,related,untracked
add action=drop chain=input comment="Drop Invalid" connection-state=invalid
"defconf: accept to local loopback (for CAPsMAN)" disabled=yes \
dst-address=127.0.0.1
add action=accept chain=input comment="WireGuard Handshake" dst-port=13231 \
protocol=udp
add action=accept chain=input comment="Winbox Router Access" dst-port=8291 \
protocol=tcp src-address=192.168.89.0/24
add action=accept chain=input comment="admin access" in-interface=Bridge-LAN \
src-address=192.168.0.0/24
add action=accept chain=input comment="users services" dst-port=53 \
in-interface=Bridge-LAN protocol=udp
in-interface=Bridge-LAN protocol=tcp
add action=drop chain=input comment="drop all else"
connection-mark=no-mark connection-state=established,related hw-offload=\
yes
"Allow Established, Related, Untracked" connection-state=\
add action=drop chain=forward comment="Drop Invalid" connection-state=invalid
add action=accept chain=forward comment="Internet Traffic" in-interface=\
Bridge-LAN out-interface="Internet In-Web Africa"
add action=accept chain=forward comment="WireGuard to LAN" in-interface=\
Pepla_WG out-interface="Internet In-Web Africa"
"Allow Local Subnet To Enter The WireGuard Interface" out-interface=\
Pepla_WG src-address=192.168.0.0/24
add action=accept chain=forward disabled=yes dst-port=19001 protocol=tcp
add action=accept chain=forward comment="Port Forwarding" \
connection-nat-state=dstnat disabled=yes
add action=drop chain=forward comment="Drop all else" connection-state=""
/ip firewall mangle
add action=accept chain=prerouting disabled=yes dst-address=192.168.0.0/24
add action=masquerade chain=srcnat comment="WireGuard NAT" disabled=yes \
out-interface=Pepla_WG src-address=192.168.89.0/24
/ip firewall service-port
set tftp disabled=yes
set irc disabled=no
set h323 disabled=yes
set sip disabled=yes
/ip ipsec profile
set [ find default=yes ] dh-group=modp2048 enc-algorithm=aes-256 \
hash-algorithm=sha512
/ip service
set ftp disabled=yes
/ppp secret
add disabled=yes name=vpn profile=*2
add disabled=yes name=JP profile=*2
/routing rule
add action=lookup disabled=no src-address=192.168.89.0/24 table=WG-Pepla
add action=lookup disabled=yes src-address=192.168.89.2/32 table=WG-Pepla
add action=lookup disabled=yes src-address=192.168.89.3/32 table=WG-Pepla
/system clock
set time-zone-name=Africa/Johannesburg
/system identity
set name="Core Router"
/system note
set show-at-login=no
Caps Config
# 2024-09-25 13:22:22 by RouterOS 7.15.3
# software id = 24LS-K6LZ
# model = RBcAPGi-5acD2nD
# serial number =
add admin-mac=48:8F:5A:38:73:B3 auto-mac=no comment=defconf name=bridgeLocal
/interface wifi datapath
add bridge=bridgeLocal comment=defconf disabled=no name=capdp
/interface wifi
# no connection to CAPsMAN
add configuration.manager=capsman datapath=capdp radio-mac=48:8F:5A:38:73:B5
add configuration.manager=capsman datapath=capdp radio-mac=48:8F:5A:38:73:B6
add bridge=bridgeLocal comment=defconf interface=ether1
add bridge=bridgeLocal comment=defconf interface=ether2
/interface wifi cap
set caps-man-addresses=192.168.0.1 certificate=request discovery-interfaces=\
bridgeLocal enabled=yes slaves-datapath=capdp slaves-static=no
/ip dhcp-client
add comment=defconf interface=bridgeLocal
/system clock
/system note
