no current-ack-timeout, overall-tx-ccq ... on my R52
Hi all
I don’t know why when I put /interface wireless monitor sektor_2 there is no:
overall-tx-ccq
current-ack-timeout
current-distance
all I see:
                 status: running-ap
                   band: 2.4ghz-b
              frequency: 2462MHz
            noise-floor: -100dBm
     registered-clients: 9
  authenticated-clients: 9
                nstreme: no
      current-tx-powers: 1Mbps:20,2Mbps:20,5.5Mbps:20,11Mbps:20
    notify-external-fdb: no
my wireless config:
 0  R name="sektor_2" mtu=1500 mac-address=00:0B:6B:4F:A2:F9 arp=enabled
      disable-running-check=no interface-type=Atheros AR5413
      radio-name="000B6B4FA2F9" mode=ap-bridge ssid="WIFI_4_SEKTOR_2"
      area="" frequency-mode=manual-txpower country=poland antenna-gain=0
      frequency=2462 band=2.4ghz-b scan-list=default rate-set=default
      supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
      supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,
                          54Mbps
      basic-rates-b=1Mbps basic-rates-a/g=6Mbps max-station-count=2007
      ack-timeout=dynamic tx-power-mode=default noise-floor-threshold=default
      periodic-calibration=default periodic-calibration-interval=60
      burst-time=disabled dfs-mode=none antenna-mode=ant-a wds-mode=disabled
      wds-default-bridge=none wds-default-cost=100 wds-cost-range=50-150
      wds-ignore-ssid=no update-stats-interval=disabled
      default-authentication=no default-forwarding=no default-ap-tx-limit=0
      default-client-tx-limit=0 proprietary-extensions=post-2.9.25
      hide-ssid=no security-profile=default disconnect-timeout=3s
      on-fail-retry-time=100ms preamble-mode=long compression=no
      allow-sharedkey=no
rb532a, routeros 2.9.40, firmware 2.6
where is the problem ??
on my another rb532a board 2.9.41 fw2.7 wher configuration is clear (/system reset-configuration) and a configure basic params like
/int wire set wlan1 band=2.4ghz-b mode=ap-bridge disabled=no
 0  R name="wlan1" mtu=1500 mac-address=00:0C:42:15:24:C2 arp=enabled
      radio-name="000C421524C2" mode=ap-bridge ssid="MikroTik" area=""
      frequency-mode=manual-txpower country=no_country_set antenna-gain=0
      frequency=2412 band=2.4ghz-b scan-list=default rate-set=default
                          54Mbps
      default-authentication=yes default-forwarding=yes default-ap-tx-limit=0
      on-fail-retry-time=100ms preamble-mode=both compression=no
      allow-sharedkey=no
and execute monitoring wlan1 I see all parameters that I want to see
                 status: running-ap
                   band: 2.4ghz-b
              frequency: 2412MHz
            noise-floor: -101dBm
         overall-tx-ccq: 94%
     registered-clients: 1
  authenticated-clients: 1
    current-ack-timeout: 30
       current-distance: 30
                nstreme: no
but for example when I change mac-address of my wireless card from 00:0C:42:15:24:C2 to let say 00:0C:42:15:24:C3 and execute monitoring wlan1 I see only this
                 status: running-ap
                   band: 2.4ghz-b
              frequency: 2412MHz
     registered-clients: 0
  authenticated-clients: 0
                nstreme: no
HOW DOES MONITORING TOOL REALY WORK ?? :slight_smile:
and another question :slight_smile:
how I can reset to default (like reset-configuration) only wireless settings ?
I’ve same problem. Any from MK could put some light on this ?
… was this after a reboot?
