Hi all,
I cannot get a DHCP address on my Wifi.
My setup is an ax³ connected to a RouterBoard, I’m using wifi with Wifi CAPsMAN.
So far I have followed mikrotik_maxslug configuration.
For now, I have two networks which are relevant:
- VLAN 99 is the management VLAN
- VLAN 10 is the main VLAN
When connecting to a VLAN 10 port, I get a DHCP address from VLAN 10.
When connecting to the VLAN 10 Wifi network, I don’t get an address for some reason even though I’m offered one.
Here is the output from nmcli (journalctl -fu NetworkManager):
Jul 04 11:16:00 simon-T14-4TB NetworkManager[2297]: <info> [1720084560.1113] device (wlp3s0): supplicant interface state: associating -> 4way_handshake
Jul 04 11:16:00 simon-T14-4TB NetworkManager[2297]: <info> [1720084560.1114] device (p2p-dev-wlp3s0): supplicant management interface state: associating -> 4way_handshake
Jul 04 11:16:00 simon-T14-4TB NetworkManager[2297]: <info> [1720084560.1539] device (wlp3s0): supplicant interface state: 4way_handshake -> completed
Jul 04 11:16:00 simon-T14-4TB NetworkManager[2297]: <info> [1720084560.1604] device (wlp3s0): ip:dhcp4: restarting
Jul 04 11:16:00 simon-T14-4TB NetworkManager[2297]: <info> [1720084560.1605] dhcp4 (wlp3s0): canceled DHCP transaction
Jul 04 11:16:00 simon-T14-4TB NetworkManager[2297]: <info> [1720084560.1606] dhcp4 (wlp3s0): activation: beginning transaction (timeout in 45 seconds)
Jul 04 11:16:00 simon-T14-4TB NetworkManager[2297]: <info> [1720084560.1606] dhcp4 (wlp3s0): state changed no lease
Jul 04 11:16:00 simon-T14-4TB NetworkManager[2297]: <info> [1720084560.1607] dhcp4 (wlp3s0): activation: beginning transaction (timeout in 45 seconds)
Jul 04 11:16:00 simon-T14-4TB NetworkManager[2297]: <info> [1720084560.1609] device (p2p-dev-wlp3s0): supplicant management interface state: 4way_handshake -> completed
Jul 04 11:16:00 simon-T14-4TB NetworkManager[2297]: <info> [1720084560.1948] dhcp4 (wlp3s0): state changed new lease, address=10.10.10.188
Jul 04 11:16:26 simon-T14-4TB NetworkManager[2297]: <info> [1720084586.3504] device (wlp3s0): disconnecting for new activation request.
Jul 04 11:16:26 simon-T14-4TB NetworkManager[2297]: <info> [1720084586.3504] device (wlp3s0): state change: activated -> deactivating (reason 'new-activation', sys-iface-state: 'managed')
Jul 04 11:16:26 simon-T14-4TB NetworkManager[2297]: <info> [1720084586.3520] audit: op="connection-activate" uuid="7cd7ab53-85de-46ed-8d22-0202549c68a8" name="SuperGame5" pid=8421 uid=1000 result="success"
Jul 04 11:16:26 simon-T14-4TB NetworkManager[2297]: <info> [1720084586.5954] device (wlp3s0): supplicant interface state: completed -> disconnected
Jul 04 11:16:26 simon-T14-4TB NetworkManager[2297]: <info> [1720084586.5954] device (p2p-dev-wlp3s0): supplicant management interface state: completed -> disconnected
Jul 04 11:16:26 simon-T14-4TB NetworkManager[2297]: <info> [1720084586.5957] device (wlp3s0): state change: deactivating -> disconnected (reason 'new-activation', sys-iface-state: 'managed')
Jul 04 11:16:26 simon-T14-4TB NetworkManager[2297]: <info> [1720084586.5974] dhcp4 (wlp3s0): canceled DHCP transaction
Jul 04 11:16:26 simon-T14-4TB NetworkManager[2297]: <info> [1720084586.5974] dhcp4 (wlp3s0): activation: beginning transaction (timeout in 45 seconds)
Jul 04 11:16:26 simon-T14-4TB NetworkManager[2297]: <info> [1720084586.5975] dhcp4 (wlp3s0): state changed no lease
Jul 04 11:16:26 simon-T14-4TB NetworkManager[2297]: <info> [1720084586.6751] device (wlp3s0): Activation: starting connection 'SuperGame5' (7cd7ab53-85de-46ed-8d22-0202549c68a8)
Jul 04 11:16:26 simon-T14-4TB NetworkManager[2297]: <info> [1720084586.6769] device (wlp3s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Jul 04 11:16:26 simon-T14-4TB NetworkManager[2297]: <info> [1720084586.6773] manager: NetworkManager state is now CONNECTING
Jul 04 11:16:26 simon-T14-4TB NetworkManager[2297]: <info> [1720084586.6778] device (wlp3s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Jul 04 11:16:26 simon-T14-4TB NetworkManager[2297]: <info> [1720084586.6784] device (wlp3s0): Activation: (wifi) access point 'SuperGame5' has security, but secrets are required.
Jul 04 11:16:26 simon-T14-4TB NetworkManager[2297]: <info> [1720084586.6784] device (wlp3s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Jul 04 11:16:26 simon-T14-4TB NetworkManager[2297]: <info> [1720084586.6787] sup-iface[da49ecdeb2db920f,1,wlp3s0]: wps: type pbc start...
Jul 04 11:16:26 simon-T14-4TB NetworkManager[2297]: <info> [1720084586.6808] device (wlp3s0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
Jul 04 11:16:26 simon-T14-4TB NetworkManager[2297]: <info> [1720084586.6814] device (wlp3s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Jul 04 11:16:26 simon-T14-4TB NetworkManager[2297]: <info> [1720084586.6819] device (wlp3s0): Activation: (wifi) connection 'SuperGame5' has security, and secrets exist. No new secrets needed.
Jul 04 11:16:26 simon-T14-4TB NetworkManager[2297]: <info> [1720084586.6820] Config: added 'ssid' value 'SuperGame5'
Jul 04 11:16:26 simon-T14-4TB NetworkManager[2297]: <info> [1720084586.6821] Config: added 'scan_ssid' value '1'
Jul 04 11:16:26 simon-T14-4TB NetworkManager[2297]: <info> [1720084586.6821] Config: added 'bgscan' value 'simple:30:-70:86400'
Jul 04 11:16:26 simon-T14-4TB NetworkManager[2297]: <info> [1720084586.6821] Config: added 'key_mgmt' value 'WPA-PSK WPA-PSK-SHA256 FT-PSK SAE FT-SAE'
Jul 04 11:16:26 simon-T14-4TB NetworkManager[2297]: <info> [1720084586.6821] Config: added 'auth_alg' value 'OPEN'
Jul 04 11:16:26 simon-T14-4TB NetworkManager[2297]: <info> [1720084586.6821] Config: added 'psk' value '<hidden>'
Jul 04 11:16:26 simon-T14-4TB NetworkManager[2297]: <info> [1720084586.7901] device (wlp3s0): supplicant interface state: disconnected -> authenticating
Jul 04 11:16:26 simon-T14-4TB NetworkManager[2297]: <info> [1720084586.7902] device (p2p-dev-wlp3s0): supplicant management interface state: disconnected -> authenticating
Jul 04 11:16:26 simon-T14-4TB NetworkManager[2297]: <info> [1720084586.8780] device (wlp3s0): supplicant interface state: authenticating -> associating
Jul 04 11:16:26 simon-T14-4TB NetworkManager[2297]: <info> [1720084586.8781] device (p2p-dev-wlp3s0): supplicant management interface state: authenticating -> associating
Jul 04 11:16:26 simon-T14-4TB NetworkManager[2297]: <info> [1720084586.9231] device (wlp3s0): supplicant interface state: associating -> associated
Jul 04 11:16:26 simon-T14-4TB NetworkManager[2297]: <info> [1720084586.9232] device (p2p-dev-wlp3s0): supplicant management interface state: associating -> associated
Jul 04 11:16:27 simon-T14-4TB NetworkManager[2297]: <info> [1720084587.0267] device (wlp3s0): supplicant interface state: associated -> 4way_handshake
Jul 04 11:16:27 simon-T14-4TB NetworkManager[2297]: <info> [1720084587.0268] device (p2p-dev-wlp3s0): supplicant management interface state: associated -> 4way_handshake
Jul 04 11:16:27 simon-T14-4TB NetworkManager[2297]: <info> [1720084587.1587] device (wlp3s0): supplicant interface state: 4way_handshake -> completed
Jul 04 11:16:27 simon-T14-4TB NetworkManager[2297]: <info> [1720084587.1588] device (wlp3s0): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network "SuperGame5"
Jul 04 11:16:27 simon-T14-4TB NetworkManager[2297]: <info> [1720084587.1588] device (p2p-dev-wlp3s0): supplicant management interface state: 4way_handshake -> completed
Jul 04 11:16:27 simon-T14-4TB NetworkManager[2297]: <info> [1720084587.1591] device (wlp3s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Jul 04 11:16:27 simon-T14-4TB NetworkManager[2297]: <info> [1720084587.1603] dhcp4 (wlp3s0): activation: beginning transaction (timeout in 45 seconds)
Jul 04 11:17:12 simon-T14-4TB NetworkManager[2297]: <info> [1720084632.0657] device (wlp3s0): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed')
Jul 04 11:17:12 simon-T14-4TB NetworkManager[2297]: <info> [1720084632.0663] manager: NetworkManager state is now CONNECTED_LOCAL
Jul 04 11:17:12 simon-T14-4TB NetworkManager[2297]: <warn> [1720084632.0669] device (wlp3s0): Activation: failed for connection 'SuperGame5'
Jul 04 11:17:12 simon-T14-4TB NetworkManager[2297]: <info> [1720084632.0673] device (wlp3s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed')
Jul 04 11:17:12 simon-T14-4TB NetworkManager[2297]: <info> [1720084632.0697] dhcp4 (wlp3s0): canceled DHCP transaction
Jul 04 11:17:12 simon-T14-4TB NetworkManager[2297]: <info> [1720084632.0698] dhcp4 (wlp3s0): activation: beginning transaction (timeout in 45 seconds)
Jul 04 11:17:12 simon-T14-4TB NetworkManager[2297]: <info> [1720084632.0698] dhcp4 (wlp3s0): state changed no lease
Jul 04 11:17:12 simon-T14-4TB NetworkManager[2297]: <info> [1720084632.3554] device (wlp3s0): supplicant interface state: completed -> disconnected
And this is the output of /log/print follow on the RouterBoard:
11:16:27 wireless,info E0:2B:E9:1B:9E:19@cap-wifi1 connected, signal strength -33
11:16:27 dhcp,debug dhcp_vlan10 received discover id 1377072291 from 0.0.0.0 '1:e0:2b:e9:1b:9e:19'
11:16:27 dhcp,debug,packet secs = 1
11:16:27 dhcp,debug,packet ciaddr = 0.0.0.0
11:16:27 dhcp,debug,packet chaddr = E0:2B:E9:1B:9E:19
11:16:27 dhcp,debug,packet Host-Name = "simon-T14-4TB"
11:16:27 dhcp,debug,packet Msg-Type = discover
11:16:27 dhcp,debug,packet Parameter-List = Subnet-Mask,Unknown(2),Domain-Server,Host-Name,Domain-Name,Interface-MTU,Broadcast-Address,Classless-Route,Router,Static-Route,Unknown(40),Unknown(41),NTP-Server,Domain-Search,MS-Classless-Route,Auto-Proxy-Config,Unknown(17)
11:16:27 dhcp,debug,packet Max-DHCP-Message-Size = 576
11:16:27 dhcp,debug,packet Client-Id = 01-E0-2B-E9-1B-9E-19
11:16:27 dhcp,debug lease not found, new lease, acquire
11:16:27 dhcp,debug ping 10.94.94.248
11:16:27 dhcp,debug ping done 10.94.94.248
11:16:27 dhcp,debug dhcp_vlan10 sending offer with id 1377072291 to 10.94.94.248
11:16:27 dhcp,debug,packet yiaddr = 10.94.94.248
11:16:27 dhcp,debug,packet siaddr = 10.94.94.1
11:16:27 dhcp,debug,packet Subnet-Mask = 255.255.255.0
11:16:27 dhcp,debug,packet Router = 10.94.94.1
11:16:27 dhcp,debug,packet Domain-Server = 10.94.94.1,192.168.178.1
11:16:27 dhcp,debug,packet NTP-Server = 192.168.178.1
11:16:27 dhcp,debug,packet Address-Time = 1800
11:16:27 dhcp,debug,packet Msg-Type = offer
11:16:27 dhcp,debug,packet Server-Id = 10.94.94.1
11:16:57 dhcp,debug lease 10.94.94.248 expired
11:17:12 wireless,info E0:2B:E9:1B:9E:19@cap-wifi1 disconnected, connection lost, signal strength -34
RB configuration:
# http://forum.mikrotik.com/t/help-me-visually-understand-routing/163980/28
# Variables:
#:global myPassword .....;
# Config:
# 1: Upstream
# 2: Direct
# 3-6: VLAN 10
# 7-8: VLAN 99
/system identity
set name=router-eg
/ip/address
add interface=ether2 address=192.168.99.1/24
# At this point, disconnect and connect to the new .99 address
/interface/vlan
add interface=bridge name=vlan10 vlan-id=10
add interface=bridge name=vlanGuest vlan-id=20
add interface=bridge name=vlanBase vlan-id=99
/ip/pool
remove [ find where name=default-dhcp ]
add name=pool_home ranges=192.168.99.160-192.168.99.254
add name=pool_vlan10 ranges=10.94.94.200-10.94.94.254
add name=pool_vlanGuest ranges=10.10.20.100-10.94.94.254
add name=pool_base ranges=10.10.99.160-10.10.99.199
/ip/dhcp-server
remove [ find where name=defconf ]
add address-pool=pool_vlan10 interface=vlan10 name=dhcp_vlan10
add address-pool=pool_vlanGuest interface=vlanGuest name=dhcp_vlanGuest
add address-pool=pool_base interface=vlanBase name=dhcp_base
add address=10.94.94.0/24 gateway=10.94.94.1
add address=10.10.20.0/24 gateway=10.10.20.1
add address=10.10.99.0/24 gateway=10.10.99.1
add address=192.168.99.0/24 gateway=192.168.99.1
/interface/bridge
set bridge protocol-mode=none
/interface/bridge/port
remove [ find where interface=ether2 ]
remove [ find where interface=ether3 ]
remove [ find where interface=ether4 ]
remove [ find where interface=ether5 ]
remove [ find where interface=ether6 ]
remove [ find where interface=ether7 ]
remove [ find where interface=ether8 ]
add bridge=bridge interface=ether3 frame-types=admit-only-untagged-and-priority-tagged pvid=10
add bridge=bridge interface=ether4 frame-types=admit-only-untagged-and-priority-tagged pvid=10
add bridge=bridge interface=ether5 frame-types=admit-only-untagged-and-priority-tagged pvid=10
add bridge=bridge interface=ether6 frame-types=admit-only-untagged-and-priority-tagged pvid=10
add bridge=bridge interface=ether7 frame-types=admit-only-vlan-tagged
add bridge=bridge interface=ether8 frame-types=admit-only-vlan-tagged
/interface/bridge/vlan
add bridge=bridge tagged=bridge,ether7,ether8 vlan-ids=10
add bridge=bridge tagged=bridge,ether7,ether8 vlan-ids=20
add bridge=bridge tagged=bridge,ether7,ether8 vlan-ids=99
remove [ find where comment=defconf ]
add address=10.10.99.1/24 interface=vlanBase
add address=10.10.20.1/24 interface=vlanGuest
add address=10.94.94.1/24 interface=vlan10
/ip dns static
remove [ find ]
add address=192.168.99.1 name=router.lan
add name=BASE
add interface=vlan10 list=LAN
add interface=vlanBase list=LAN
add interface=vlanBase list=BASE
remove [ find where interface=bridge ]
set discover-interface-list=BASE
# Disable because insecure
/tool mac-server
# Only allow WinBox access from trunk ports
/tool mac-server mac-winbox
set allowed-interface-list=BASE
remove [ find where comment="defconf: drop all not coming from LAN" ]
add action=accept chain=input comment="Allow management access" in-interface-list=BASE
add action=accept chain=input comment="Allow emergency port access" in-interface=ether2
add action=accept chain=input comment="Users: Services access" in-interface-list=LAN dst-port=53 protocol=tcp
add action=accept chain=input comment="Users: Services access" in-interface-list=LAN dst-port=53 protocol=udp
add action=drop chain=input comment="Drop all other traffic"
remove [ find where comment="defconf: drop all from WAN not DSTNATed" ]
add action=accept chain=forward comment="internet traffic" in-interface-list=LAN out-interface-list=WAN
add action=accept chain=forward comment="port forwarding" connection-nat-state=dstnat disabled=yes
add action=drop chain=forward comment="drop all else"
/ipv6 settings set disable-ipv6=yes max-neighbor-entries=8192
# From https://help.mikrotik.com/docs/display/ROS/WiFi#WiFi-CAPsMAN-CAPsimpleconfigurationexample:
/interface/wifi/datapath
add bridge=bridge name=DP_10 client-isolation=no vlan-id=10
add bridge=bridge name=DP_Guest client-isolation=yes vlan-id=20
/interface wifi security
add authentication-types=wpa2-psk,wpa3-psk ft=yes ft-over-ds=yes name=SEC_GAME passphrase=$myPassword
add authentication-types=wpa2-psk,wpa3-psk ft=yes ft-over-ds=yes name=SEC_GUEST passphrase=supergut
# Creating a common configuration profile and linking the security profile to it
/interface wifi configuration
add datapath=DP_10 name=CONF_GAME_2G security=SEC_GAME ssid=SuperGame2 country=Switzerland channel.band=2ghz-n
add datapath=DP_Guest name=CONF_GUEST_2G security=SEC_GUEST ssid="Supergut Guest" country=Switzerland channel.band=2ghz-n
add datapath=DP_10 name=CONF_GAME_5G security=SEC_GAME ssid=SuperGame5 country=Switzerland channel.band=5ghz-ax
add datapath=DP_Guest name=CONF_GUEST_5G security=SEC_GUEST ssid="Supergut Guest" country=Switzerland channel.band=5ghz-ax
/interface/wifi/capsman
set enabled=yes interfaces=vlanBase certificate=auto ca-certificate=auto
# Creating separate channel configurations for each band
#/interface wifi channel
#add name=ch-2ghz frequency=2412,2432,2472 width=20mhz
#add name=ch-5ghz frequency=5180,5260,5500 width=20/40/80mhz
# Assigning to each interface the common profile as well as band-specific channel profile
/interface wifi provisioning
add action=create-dynamic-enabled master-configuration=CONF_GAME_5G slave-configuration=CONF_GUEST_5G supported-bands=5ghz-ax
add action=create-dynamic-enabled master-configuration=CONF_GAME_2G slave-configuration=CONF_GUEST_2G supported-bands=2ghz-n
/interface/bridge
set vlan-filtering=yes [ find where name=bridge ]
ax³ configuration:
# Adapted from https://github.com/maxslug/mikrotik_maxslug/blob/master/wap1.rsc
# Initial setup: Router, defconf
# Target setup:
# ether1 = trunk
# ether2 = local conn
# ether3 = VLAN 10
# ether4 = trunk
# ether5 = trunk
# wlan1 = CAP
# wlan2 = CAP (if wlan2 available)
## Connect to ether2 for setup. ##
## EG ##
#:global myIp 10.10.99.20/24; :global myLocalIp 192.168.99.20/24; :global myName ax3-super-eg;
## UG ##
#:global myIp 10.10.99.21/24; :global myLocalIp 192.168.99.21/24; :global myName ax3-super-ug;
/system identity
set name=$myName
/system/clock set time-zone-name=Europe/Zurich
/ip/address
add interface=ether2 address=$myLocalIp
## Now, connect to new address ##
## Also, define variables again (lost after logout) ##
# First, drop unused routing defconf
/ip/firewall/filter/remove [ find where dynamic=no ]
/ip/firewall/nat/remove [ find where dynamic=no ]
/ipv6/firewall/filter/remove [ find where dynamic=no ]
/ipv6/firewall/address-list/remove [ find ]
/ip/dhcp-client/remove [ find where comment=defconf ]
/ip/dhcp-server/remove [ find where name=defconf ]
/ip/dhcp-server/network/remove [ find where comment=defconf ]
/ip/pool/remove [ find name=default-dhcp ]
/ip/dns/static/remove [ find where comment=defconf ]
/interface/list/member/remove [ find where interface=ether1 ]
/interface/list/remove [ find where name=WAN ]
/interface wifi
set [ find default-name=wifi1 ] configuration.manager=capsman .mode=ap disabled=no
set [ find default-name=wifi2 ] configuration.manager=capsman .mode=ap disabled=no
add master-interface=wifi1 name=wifi1_guest disabled=no
add master-interface=wifi2 name=wifi2_guest disabled=no
/interface/bridge
remove [ find where interface=wifi1 ]
remove [ find where interface=wifi2 ]
add bridge=bridge interface=ether1 trusted=yes frame-types=admit-only-vlan-tagged
add bridge=bridge interface=ether4 frame-types=admit-only-vlan-tagged
add bridge=bridge interface=ether5 frame-types=admit-only-vlan-tagged
add bridge=bridge interface=wifi1 pvid=10 frame-types=admit-only-untagged-and-priority-tagged ingress-filtering=yes comment="2G Game"
add bridge=bridge interface=wifi1_guest pvid=20 frame-types=admit-only-untagged-and-priority-tagged ingress-filtering=yes comment="2G Guest"
add bridge=bridge interface=wifi2 pvid=10 frame-types=admit-only-untagged-and-priority-tagged ingress-filtering=yes comment="5G Game"
add bridge=bridge interface=wifi2_guest pvid=20 frame-types=admit-only-untagged-and-priority-tagged ingress-filtering=yes comment="5G Guest"
add bridge=bridge tagged=bridge,ether1,ether4,ether5 untagged=ether2,wifi1,wifi2 vlan-ids=10
add bridge=bridge tagged=bridge,ether1,ether4,ether5 untagged=wifi1_guest,wifi2_guest vlan-ids=20
# TODO Add ether2 as untagged for management VLAN?
add bridge=bridge tagged=bridge,ether1,ether4,ether5 vlan-ids=99
# No need to define VLAN 10 because no L3 needed there
/interface vlan
/ip/address
add interface=vlanBase address=$myIp
/ip/route
add distance=1 gateway=10.10.99.1
# DNS through trusted subnet gateway
set allow-remote-requests=yes servers=10.10.99.1
/ip/route
add disabled=no dst-address=0.0.0.0/0 gateway=10.10.99.1 comment="ensures route avail through trusted subnet gateway"
# Enable CAPsMAN
/interface wifi cap
set enabled=yes discovery-interfaces=vlanBase caps-man-addresses=10.10.99.1 slaves-static=yes
### Config + WAP Security
/interface/list
add name=MANAGE
add interface=vlanBase list=MANAGE
set discover-interface-list=MANAGE
/tool mac-server
# Only allow WinBox access from management VLAN
set allowed-interface-list=MANAGE
# Enable VLAN mode
/interface/bridge
What is wrong here?
Thanks,
Simon
