I have had a hAP ac2 working as my home router for couple years. Wireless interfaces on hAP ac2 are setup to be managed by CAPsMAN (I setup some networks with CAPs before, and they work; applying the same config) and it has been working standalone. Bog stand WAN->ROUTER(DHCP) → WIFI setup.
I recently acquired a CAP lite to boost the reach of my home wifi. For the life of me, I can’t seem to get IP from the CAP.
Both devices have the latest 6.49 firmware, and CAP was reset in CAP mode.
CAPsMAN sees and seemingly provisions everything. I can see the SSID from CAP (Wifi analyzer shows 1x 5ghz from hAP, 1x 2.4ghz from hAP, and 1x 2.4ghz from CAP), but cannot acquire IP from it. I de-provision the two hAP interfaces so to force my device to go through the CAP. Something seems to be blocking the traffic from reaching DHCP server and I can’t figure out what’s missing (firewall rule perhaps?).
Help appreciated.
Below are the configurations; top section is CAP, the bottom section is hAP; I can’t seem to get two code tags to render correctly. ![]()
# oct/09/2021 13:22:42 by RouterOS 6.49
# software id = T3JY-V9M9
# model = RouterBOARD cAP L-2nD
add admin-mac=6C:3B:6B:EC:92:B2 auto-mac=no fast-forward=no name=bridgeLocal
/interface wireless
# managed by CAPsMAN
# channel: 2442/20-Ce/gn(30dBm), SSID: MonkeyHome, local forwarding
set [ find default-name=wlan1 ] antenna-gain=0 country=no_country_set disabled=no frequency-mode=manual-txpower rx-chains=0 ssid=MikroTik tx-chains=0
set [ find default-name=ether1 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
/snmp community
set [ find default=yes ] addresses=0.0.0.0/0
/user group
set full policy=local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,password,web,sniff,sensitive,api,romon,dude,tikapp
/interface wireless cap
set bridge=bridgeLocal certificate=request discovery-interfaces=ether1 enabled=yes interfaces=wlan1 lock-to-caps-man=yes static-virtual=yes
/ip dhcp-client
add disabled=no interface=ether1
/system clock
set time-zone-name=Asia/Hong_Kong
/system identity
set name=cap-lite-room
/system routerboard settings
set auto-upgrade=yes
# oct/09/2021 12:50:21 by RouterOS 6.49
# software id = PKZ5-LSG9
# model = RouterBOARD D52G-5HacD2HnD-TC
/caps-man channel
add band=2ghz-onlyn extension-channel=Ce name=2ghz-cap-channel reselect-interval=5m skip-dfs-channels=yes
add band=5ghz-n/ac extension-channel=Ceee name=5ghz-cap-channel reselect-interval=3m skip-dfs-channels=yes
add admin-mac=CC:2D:E0:EB:62:51 auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] name=ether1-wan rx-flow-control=auto speed=100Mbps tx-flow-control=auto
set [ find default-name=ether2 ] rx-flow-control=auto speed=100Mbps tx-flow-control=auto
set [ find default-name=ether3 ] rx-flow-control=auto speed=100Mbps tx-flow-control=auto
set [ find default-name=ether4 ] rx-flow-control=auto speed=100Mbps tx-flow-control=auto
set [ find default-name=ether5 ] rx-flow-control=auto speed=100Mbps tx-flow-control=auto
/interface wireless
# channel: 2422/20-Ce/gn(30dBm), SSID: MonkeyHome, local forwarding
set [ find default-name=wlan1 ] antenna-gain=0 band=2ghz-g/n channel-width=20/40mhz-Ce country=no_country_set disabled=no distance=indoors frequency=auto frequency-mode=manual-txpower mode=ap-bridge name=wlan2.4-iface ssid=MonkeyHome station-roaming=enabled \
wireless-protocol=802.11
# channel: 5180/20-Ceee/ac(17dBm), SSID: MonkeyHome, local forwarding
set [ find default-name=wlan2 ] antenna-gain=0 band=5ghz-a/n/ac channel-width=20/40/80mhz-Ceee country="hong kong" disabled=no distance=indoors frequency=auto frequency-mode=manual-txpower mode=ap-bridge name=wlan5-iface ssid=MonkeyHome station-roaming=enabled \
/caps-man datapath
add bridge=bridge client-to-client-forwarding=no local-forwarding=yes name=share-datapath
/caps-man security
add authentication-types=wpa2-psk encryption=aes-ccm name=monkey-home-security passphrase=fathinfathin
/caps-man configuration
add channel=2ghz-cap-channel datapath=share-datapath datapath.bridge=bridge name=2ghz-config security=monkey-home-security ssid=MonkeyHome
add channel=5ghz-cap-channel datapath=share-datapath datapath.bridge=bridge name=5ghz-config security=monkey-home-security ssid=MonkeyHome
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk disable-pmkid=yes mode=dynamic-keys supplicant-identity=MikroTik wpa-pre-shared-key=badpw wpa2-pre-shared-key=badpw
add name=dhcp ranges=192.168.88.100-192.168.88.254
add address-pool=dhcp disabled=no interface=bridge name=dhcp-default
/ipv6 dhcp-server
add address-pool=ISP-ipv6 allow-dual-stack-queue=no interface=bridge lease-time=30m name=mikrotik-dhcp-server-v6
/user group
/caps-man manager
set ca-certificate=auto certificate=auto enabled=yes upgrade-policy=require-same-version
/caps-man provisioning
add action=create-dynamic-enabled comment=2ghz hw-supported-modes=gn,g master-configuration=2ghz-config name-format=prefix-identity name-prefix=2ghz-vlan
add action=create-dynamic-enabled comment=5ghz hw-supported-modes=ac,an master-configuration=5ghz-config name-format=prefix-identity name-prefix=5ghz-vlan
add bridge=bridge comment=defconf interface=wlan2.4-iface
add bridge=bridge comment=defconf interface=wlan5-iface
add bridge=bridge interface=dynamic
/interface bridge settings
set use-ip-firewall=yes use-ip-firewall-for-vlan=yes
add comment=defconf interface=ether1-wan list=WAN
set bridge=bridge certificate=request discovery-interfaces=bridge enabled=yes interfaces=wlan2.4-iface,wlan5-iface lock-to-caps-man=yes static-virtual=yes
add address=192.168.88.1/24 comment=defconf interface=ether2 network=192.168.88.0
add address=10.0.10.1/24 comment="bridge vlan admin address" network=10.0.10.0
add address=10.0.20.1/24 comment="bridge vlan guest address" network=10.0.20.0
add address=192.168.88.10/24 interface=bridge network=192.168.88.0
/ip dhcp-client
add comment=defconf disabled=no interface=ether1-wan
/ip dhcp-server lease
add address=192.168.88.104 client-id=1:70:85:c2:30:3a:bc mac-address=70:85:C2:30:3A:BC server=dhcp-default
add address=192.168.88.105 client-id=1:dc:a6:32:1b:c5:36 mac-address=DC:A6:32:1B:C5:36 server=dhcp-default
add address=192.168.88.0/24 comment=defconf dns-server=192.168.88.1 domain=home gateway=192.168.88.10
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4,2001:4860:4860::8888,2001:4860:4860::8844
add action=accept chain=input comment="CAPsMAN local" dst-address-type=local src-address-type=local
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/ip ssh
set allow-none-crypto=yes forwarding-enabled=remote
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=bridge type=internal
/ipv6 address
add address=::ce2d:e0ff:feeb:6251 from-pool=ISP-ipv6 interface=bridge
/ipv6 dhcp-client
add add-default-route=yes interface=ether1-wan pool-name=ISP-ipv6 request=prefix
/ipv6 firewall address-list
add address=::224.0.0.0/100 comment="defconf: other" list=bad_ipv6
add address=::127.0.0.0/104 comment="defconf: other" list=bad_ipv6
add address=::/104 comment="defconf: other" list=bad_ipv6
add address=::255.0.0.0/104 comment="defconf: other" list=bad_ipv6
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=33434-33534 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp src-address=fe80::/16
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
/ipv6 nd
set [ find default=yes ] interface=bridge managed-address-configuration=yes other-configuration=yes ra-lifetime=15m
/ipv6 nd prefix
add autonomous=no interface=bridge
/system clock
/system identity
set name=monkey
/system ntp client
set enabled=yes primary-ntp=118.143.17.82 secondary-ntp=162.159.200.123
/system ntp server
set enabled=yes
set auto-upgrade=yes cpu-frequency=auto
/tool mac-server
/tool mac-server mac-winbox
