I've been pulling my hair out since about 3pm yesterday.
I reset my router, so I could do a clean configuration, and so far it PARTIALLY works.
Basically I have 1 bridge and 5 VLANs. 2 of the VLANs are tied to a single port each. Those two work perfectly, DHCP supplies an address and they can connect to the internet (well, the CAM-VLAN can't get to the internet, but it's not supposed to.
The other 3 VLANs can come from either ether1 or ether2. Ether1 and ether2 are connected to unmanaged switches. Nothing plugged into those switches gets an IP address.
I read through so many tutorials, and I feel like I'm missing something small.
Anyway, here's the config:
# 2025-11-10 10:31:35 by RouterOS 7.20.4
# software id = XXXXXX
# model = RB5009UPr+S+
# serial number = XXXXXXX
add admin-mac=xx:xx:xx:xx:xx:xx auto-mac=no comment=defconf fast-forward=no \
frame-types=admit-only-vlan-tagged name=bridge vlan-filtering=yes
/interface vlan
add interface=bridge name=CAM-VLAN vlan-id=20
add interface=bridge name=DL-VLAN vlan-id=40
add interface=bridge name=IOT-VLAN vlan-id=10
add interface=bridge name=MAIN-VLAN vlan-id=50
add interface=bridge name=MEDIA-VLAN vlan-id=30
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=MGMT
add name=IOT-POOL ranges=192.168.10.2-192.168.10.254
add name=CAM-POOL ranges=192.168.20.2-192.168.20.254
add name=MEDIA-POOL ranges=192.168.30.2-192.168.30.254
add name=DL-POOL ranges=192.168.40.2-192.168.40.254
add name=MAIN-POOL ranges=192.168.50.2-192.168.50.254
add address-pool=default-dhcp interface=ether7 name=MGMT
add address-pool=IOT-POOL interface=IOT-VLAN name=IOT-DHCP
add address-pool=CAM-POOL interface=CAM-VLAN name=CAM-DHCP
add address-pool=MEDIA-POOL interface=MEDIA-VLAN name=MEDIA-DHCP
add address-pool=DL-POOL interface=DL-VLAN name=DL-DHCP
add address-pool=MAIN-POOL interface=MAIN-VLAN name=MAIN-DHCP
/disk settings
set auto-media-interface=bridge auto-media-sharing=yes auto-smb-sharing=yes
add bridge=bridge comment=defconf frame-types=admit-only-vlan-tagged \
interface=ether1
interface=ether2
add bridge=bridge comment=defconf frame-types=\
admit-only-untagged-and-priority-tagged interface=ether3 pvid=20
interface=ether4
interface=ether5
admit-only-untagged-and-priority-tagged interface=ether6 pvid=40
set discover-interface-list=MGMT
/ipv6 settings
set disable-ipv6=yes forward=no
/interface bridge vlan
add bridge=bridge comment=IOT-VLAN tagged=ether1,ether2,bridge vlan-ids=10
add bridge=bridge comment=CAM-VLAN tagged=bridge untagged=ether3 vlan-ids=20
add bridge=bridge comment=MEDIA-VLAN tagged=ether1,ether2,bridge vlan-ids=30
add bridge=bridge comment=DL-VLAN tagged=bridge untagged=ether6 vlan-ids=40
add bridge=bridge comment=MAIN-VLAN tagged=ether1,ether2,bridge vlan-ids=50
add interface=CAM-VLAN list=LAN
add comment=defconf interface=ether8 list=WAN
add interface=ether7 list=MGMT
add interface=MAIN-VLAN list=MGMT
add interface=ether7 list=LAN
add interface=IOT-VLAN list=LAN
add interface=MEDIA-VLAN list=LAN
add interface=DL-VLAN list=LAN
add interface=MAIN-VLAN list=LAN
add address=192.168.88.1/24 comment=defconf interface=ether7 network=\
192.168.88.0
add address=192.168.10.1/24 comment=IOT-ADDR interface=IOT-VLAN network=\
192.168.10.0
add address=192.168.20.1/24 comment=CAM-ADDR interface=CAM-VLAN network=\
192.168.20.0
add address=192.168.30.1/24 comment=MEDIA-ADDR interface=MEDIA-VLAN network=\
192.168.30.0
add address=192.168.40.1/24 comment=DL-ADDR interface=DL-VLAN network=\
192.168.40.0
add address=192.168.50.1/24 comment=MAIN-ADDR interface=MAIN-VLAN network=\
192.168.50.0
/ip dhcp-client
add address=192.168.10.0/24 comment="IOT Network" dns-server=1.1.1.1 gateway=\
192.168.10.1
add address=192.168.20.0/24 comment="CAM Network" dns-server=1.1.1.1 gateway=\
192.168.20.1
add address=192.168.30.0/24 comment="MEDIA Network" dns-server=1.1.1.1 \
gateway=192.168.30.1
add address=192.168.40.0/24 comment="DL Network" dns-server=1.1.1.1 gateway=\
192.168.40.1
add address=192.168.50.0/24 comment="MAIN Network" dns-server=1.1.1.1 \
gateway=192.168.50.1
add address=192.168.88.0/24 comment=defconf dns-server=1.1.1.1 gateway=\
192.168.88.1
set allow-remote-requests=yes servers=1.1.1.1
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan type=A
established,related,untracked disabled=yes
invalid disabled=yes
add action=accept chain=input comment="defconf: accept ICMP" disabled=yes \
protocol=icmp
"defconf: accept to local loopback (for CAPsMAN)" disabled=yes \
dst-address=127.0.0.1
disabled=yes in-interface-list=!LAN
disabled=yes ipsec-policy=in,ipsec
disabled=yes ipsec-policy=out,ipsec
connection-state=established,related disabled=yes hw-offload=yes
connection-state=invalid disabled=yes
connection-state=new disabled=yes in-interface-list=WAN
add action=accept chain=input comment="Allow Estab & Related" \
add action=accept chain=input comment="Allow LAN" in-interface-list=LAN
add action=accept chain=input comment="Allow MAIN-VLAN Full Access" \
in-interface=MAIN-VLAN
add action=drop chain=input comment=Drop
add action=accept chain=forward comment="Allow Estab & Related" \
add action=accept chain=forward comment="LAN Internet Access only" \
connection-state=new in-interface-list=LAN out-interface-list=WAN
add action=drop chain=forward comment=Drop
add action=drop chain=forward comment="Drop CAM from Internet" in-interface=\
CAM-VLAN out-interface-list=WAN
add action=accept chain=forward comment="MAIN-VLAN inter-VLAN routing" \
connection-state=new in-interface=MAIN-VLAN
/ip smb shares
set [ find default=yes ] directory=flash/pub
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" \
dst-port=33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/system clock
set time-zone-name=America/Chicago
/tool mac-server
/tool mac-server mac-winbox
set allowed-interface-list=MGMT
