No DNS on wlan
Hi
just installed Mikrotik RBD53iG-5HacD2HnD. The problem is accessing from WLAN has no internet connection, but from LAN no issue. Devices on WLAN get IP, I can ping for example 8.8.8.8. It is probably a DNS issue.
Here is my config
# apr/20/2025 09:40:32 by RouterOS 7.2.3
# software id = UF9Q-C7WL
# model = RBD53iG-5HacD2HnD
# serial number = HD108261KST
add admin-mac=18:FD:74:88:0E:4C auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX country="czech republic" disabled=no distance=indoors frequency=auto installation=indoor mode=ap-bridge ssid=Mikro2GH119 wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX country="czech republic" disabled=no distance=indoors frequency=auto installation=indoor mode=ap-bridge ssid=Mikro5GH119 wireless-protocol=802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=dynamic-keys supplicant-identity=MikroTik
add name=dhcp ranges=192.168.119.10-192.168.119.254
add address-pool=dhcp interface=bridge name=defconf
add bridge=bridge comment=defconf interface=wlan2
add address=192.168.119.1/24 comment=defconf interface=bridge network=192.168.119.0
/ip dhcp-client
add address=192.168.119.0/24 comment=defconf dns-server=192.168.88.1 gateway=192.168.119.1 netmask=24
set allow-remote-requests=yes use-doh-server=1.1.1.1
/ip dns static
add address=192.168.1.1 comment=defconf name=router.lan
add address=8.8.8.8 name=google
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/ipv6 firewall address-list
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=33434-33534 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
/system clock
set time-zone-name=Europe/Prague
Thanks for replies
You have remnants of the default config
  1. From:
    TO:
    add address=192.168.119.0/24 comment=defconf dns-server=192.168.119.1 gateway=192.168.119.1 netmask=24
  2. Remove these static addresses
    /ip dns static
  3. Your router seems very UNSAFE missing any input chain rules. you need some right away.
add action=accept chain=input connection-state=established,related,untracked
add action=drop chain=input connection-state=invalid
add action=accept chain=input dst-address=127.0.0.1
add action=accept chain=input comment=“LAN access” in-interface-list=LAN
add action=drop chain=input comment=“Drop all else”
{ insert this rule here, after the above accept LAN RULE, but last of all rules to avoid getting locked out }
add action=accept chain=forward comment=“defconf: accept in ipsec policy” ipsec-policy=in,ipsec
add action=accept chain=forward comment=“defconf: accept out ipsec policy” ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment=“defconf: fasttrack” connection-state=established,related hw-offload=yes
add action=accept chain=forward comment=“defconf: accept established,related, untracked” connection-state=established,related,untracked
add action=drop chain=forward comment=“defconf: drop invalid” connection-state=invalid
add action=drop chain=forward comment=“defconf: drop all from WAN not DSTNATed” connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
  1. With the changes above and its not working then you will need to fix your DNS DOH configuration.
