Hi, does anyone have any idea why, even though the MikroTik logs show that the VM on Proxmox is receiving an IP (Topics: dhcp, info), the machine isn't showing up in MikroTik's Leases?
I'm working on the following configuration:
a) The VM I'm attaching vlan tag 111 to receives a private address from the 192.168.111.XXX pool, as well as the public address XXX.XXX.XXX.111
b) The VM I'm attaching vlan tag 222 to receives a private address from the 192.168.222.XXX pool, as well as the public address XXX.XXX.XXX.222
etc... and it works. There's internet, local and public addresses are assigned correctly, but there's no trace of this in the leases (regarding the private ones).
I'm running on a single bridge, vmbr0, and I simply assign vlan tags of 111 or 222 there (it was the same on separate bridges).
The response to changes in the IP-->pool is there - the machine's address changes (I can only see this in the network settings directly on the VM or in the MikroTik log).
Problem to solve: I need to set a static address for selected machines; setting the address on the machine doesn't work.
Where can I find information about the leased machines or manage their address if they're not listed in Leases and accessing them on the VM doesn't help? ![]()
