I’m having a problem getting the Ethernet to PC side working. POE seems to be working fine. The RB they sent me was a 911L-2nD so I hoping there is no difference between the one I ordered RB911-2Hn Lite 2 and the 2nD
On the router board there is a light on either side of the ethernet plug and those are on.
Then there is 6 other lights to the right hand side the last three are on, the 1st three are not.
I have it connected to a 12db Omni. I wanted to set it up for CPE so I can use it to get the feed from our
provider.
I have the POE setup
Positive uses: Blue/White - Blue
Negative uses: Brown/White - Brown
I tried using A & B side on the ethernet jacks. Even tried a crossover cable and that didn’t
help.
I tried the cable setup mentioned http://wiki.mikrotik.com/wiki/Manual:PoE-In but that didn’t work
at all.
Using standard w/Orange, Orange, w/Green, Blue, w/Blue, Green, w/Brown, Brown, Powers
RB fine, just no network available.
I have tried 9VDC, 12VDC, 24VDC 1000mA max and the same issue.
I tried Windows 10 and Ubuntu 14.04 and get no network cable connected error.
This was a brand new board from Baltic.
Thanks in advance for any help you can give.
Bob
