No external access to router after load balancing
So I setup load balancing on my RB751U-2HnD and it works great but I can’t get external access to the router to work. I’m sure its replying to request from the wrong interface but I can’t see why. From the router itself I can ping out successfully but pinging to the router externally or ssh, winbox, and webmin, are all unsuccessful. Here is what I used to get load balancing setup:
 0   chain=prerouting action=mark-routing new-routing-mark=WAN1 passthrough=no src-address=192.168.0.0/23
     dst-address=!192.168.0.0/23 nth=2,1
 1   chain=prerouting action=mark-routing new-routing-mark=WAN2 passthrough=no src-address=192.168.0.0/23
 0 A S  dst-address=0.0.0.0/0 gateway=***.***.***.*** gateway-status=***.***.***.*** reachable via  ether1-gateway check-gateway=ping distance=1 scope=30 target-scope=10 routing-mark=WAN1
 1 A S  dst-address=0.0.0.0/0 gateway=***.***.***.*** gateway-status=***.***.***.*** reachable via  ether5-WAN2 check-gateway=ping distance=1 scope=30 target-scope=10 routing-mark=WAN2
Is the external address in the range of 192.168.0.0/23? You can create a different subnet which is not being processed or you create an accept rule for the identified traffic above the mangle rules and it should clear up that problem.
Thank you for your reply; it got me to think outside of the box. I found the problem was that the 0.0.0.0/0 was set to only marked routes WAN1 and WAN2 and none for the default main. All started working when I added 2 more 0.0.0.0/0 routes with the default settings.
