No green light on ethernet port
I have problems with connecting some LAN devices to CCR1009. If I connect PC to any port on CCR I get IP from DHCP and green light is on and amber light is flashing.
But If I connect to any port other equipment media-player, sat-receiver… then only amber light is flashing slowly, green light is OFF and DHCP does not supply IP to those devices.
If I connect devices to RB2011 they works normal.
Is there something with settings?
you can check if the ethernet ports are set to auto negotiate their link speed.
Also is the same thing happening when you plug both ends of the same cable into the router?
Check auto-negotiation of your Ethernet ports.
I tried with auto negotiatio ON and also OFF and manual settings but no success.
Green light will on when you connect to a gigabit ethernet port.
Tnx:)
