No internet access after hotspot enabled
Hi all, im trying to setup a wds hotspot for a school. my setup works fine without the hotspot enabled. as soon as I enable the hotspot all internet access disappears, even the the hotspot itself. My config is as follows
 interface export
# oct/16/2011 13:40:12 by RouterOS 5.7
# software id = IGS7-FA9S
add admin-mac=00:00:00:00:00:00 ageing-time=5m arp=enabled auto-mac=yes disabled=no forward-delay=15s l2mtu=2290 max-message-age=20s mtu=1500 name=bridge1 \
    priority=0x8000 protocol-mode=rstp transmit-hold-count=6
set 0 arp=enabled auto-negotiation=yes disabled=no full-duplex=yes l2mtu=1526 mac-address=00:0C:42:C9:6B:BB mtu=1500 name=ether1 speed=100Mbps
set default authentication-types="" eap-methods=passthrough group-ciphers="" group-key-update=5m interim-update=0s management-protection=disabled \
    management-protection-key="" mode=none name=default radius-eap-accounting=no radius-mac-accounting=no radius-mac-authentication=no radius-mac-caching=\
    disabled radius-mac-format=XX:XX:XX:XX:XX:XX radius-mac-mode=as-username static-algo-0=none static-algo-1=none static-algo-2=none static-algo-3=none \
    static-key-0="" static-key-1="" static-key-2="" static-key-3="" static-sta-private-algo=none static-sta-private-key="" static-transmit-key=key-0 \
    supplicant-identity=MikroTik tls-certificate=none tls-mode=no-certificates unicast-ciphers="" wpa-pre-shared-key="" wpa2-pre-shared-key=""
add authentication-types=wpa-psk,wpa2-psk group-ciphers=tkip group-key-update=5m interim-update=0s management-protection=allowed management-protection-key="" \
    mode=dynamic-keys name=profile1 radius-eap-accounting=no radius-mac-accounting=no radius-mac-authentication=no radius-mac-caching=disabled \
    radius-mac-format=XX:XX:XX:XX:XX:XX radius-mac-mode=as-username static-algo-0=none static-algo-1=none static-algo-2=none static-algo-3=none static-key-0="" \
    static-key-1="" static-key-2="" static-key-3="" static-sta-private-algo=none static-sta-private-key="" static-transmit-key=key-0 supplicant-identity="" \
    tls-certificate=none tls-mode=no-certificates unicast-ciphers=tkip wpa-pre-shared-key=riaan4rachel wpa2-pre-shared-key=riaan4rachel
/interface wireless
set 0 adaptive-noise-immunity=none allow-sharedkey=no antenna-gain=0 antenna-mode=ant-a area="" arp=enabled band=2ghz-b basic-rates-a/g=6Mbps basic-rates-b=\
    1Mbps bridge-mode=enabled burst-time=disabled channel-width=20mhz compression=no country=no_country_set default-ap-tx-limit=0 default-authentication=yes \
    default-client-tx-limit=0 default-forwarding=yes dfs-mode=none disable-running-check=no disabled=no disconnect-timeout=3s distance=dynamic frame-lifetime=0 \
    frequency=2412 frequency-mode=manual-txpower frequency-offset=0 hide-ssid=no hw-fragmentation-threshold=disabled hw-protection-mode=none \
    hw-protection-threshold=0 hw-retries=7 l2mtu=2290 mac-address=00:0C:42:C9:6B:BC max-station-count=2007 mode=station mtu=1500 name=wlan1 \
    noise-floor-threshold=default nv2-cell-radius=30 nv2-noise-floor-offset=default nv2-preshared-key="" nv2-qos=default nv2-queue-count=2 nv2-security=\
    disabled on-fail-retry-time=100ms periodic-calibration=default periodic-calibration-interval=60 preamble-mode=both proprietary-extensions=post-2.9.25 \
    radio-name=000C42C96BBC rate-selection=legacy rate-set=default scan-list=default security-profile=profile1 ssid=spies station-bridge-clone-mac=\
    00:00:00:00:00:00 supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps tdma-period-size=2 \
    tx-power-mode=default update-stats-interval=disabled wds-cost-range=50-150 wds-default-bridge=none wds-default-cost=100 wds-ignore-ssid=no wds-mode=\
    disabled wireless-protocol=unspecified wmm-support=disabled
set 1 adaptive-noise-immunity=none allow-sharedkey=no antenna-gain=0 area="" arp=enabled band=2ghz-b/g basic-rates-a/g=6Mbps basic-rates-b=1Mbps bridge-mode=\
    enabled channel-width=20mhz compression=no country=no_country_set default-ap-tx-limit=0 default-authentication=yes default-client-tx-limit=0 \
    default-forwarding=no dfs-mode=none disable-running-check=no disabled=no disconnect-timeout=3s distance=dynamic frame-lifetime=0 frequency=2412 \
    frequency-mode=manual-txpower frequency-offset=0 hide-ssid=no ht-ampdu-priorities=0 ht-amsdu-limit=8192 ht-amsdu-threshold=8192 ht-basic-mcs=\
    mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7 ht-guard-interval=any ht-rxchains=0 ht-supported-mcs="mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,\
    mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15,mcs-16,mcs-17,mcs-18,mcs-19,mcs-20,mcs-21,mcs-22,mcs-23" ht-txchains=0 hw-fragmentation-threshold=disabled \
    hw-protection-mode=none hw-protection-threshold=0 hw-retries=7 l2mtu=2290 mac-address=00:0C:42:67:01:1E max-station-count=2007 mode=ap-bridge mtu=1500 \
    name=wlan2 noise-floor-threshold=default nv2-cell-radius=30 nv2-noise-floor-offset=default nv2-preshared-key="" nv2-qos=default nv2-queue-count=2 \
    nv2-security=disabled on-fail-retry-time=100ms periodic-calibration=default periodic-calibration-interval=60 preamble-mode=both proprietary-extensions=\
    post-2.9.25 radio-name=000C4267011E rate-selection=legacy rate-set=default scan-list=default security-profile=default ssid="Edenglen WIFI" \
    station-bridge-clone-mac=00:00:00:00:00:00 supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps supported-rates-b=\
    1Mbps,2Mbps,5.5Mbps,11Mbps tdma-period-size=2 tx-power-mode=default update-stats-interval=disabled wds-cost-range=50-150 wds-default-bridge=none \
    wds-default-cost=100 wds-ignore-ssid=no wds-mode=disabled wireless-protocol=unspecified wmm-support=disabled
/interface wireless manual-tx-power-table
set wlan1 manual-tx-powers="1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,6Mbps:17,9Mbps:17,12Mbps:17,18Mbps:17,24Mbps:17,36Mbps:17,48Mbps:17,54Mbps:17,HT20-0:17,HT20-\
    1:17,HT20-2:17,HT20-3:17,HT20-4:17,HT20-5:17,HT20-6:17,HT20-7:17,HT40-0:17,HT40-1:17,HT40-2:17,HT40-3:17,HT40-4:17,HT40-5:17,HT40-6:17,HT40-7:17"
set wlan2 manual-tx-powers="1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,6Mbps:17,9Mbps:17,12Mbps:17,18Mbps:17,24Mbps:17,36Mbps:17,48Mbps:17,54Mbps:17,HT20-0:17,HT20-\
/interface wireless nstreme
set wlan1 disable-csma=no enable-nstreme=no enable-polling=yes framer-limit=3200 framer-policy=none
set wlan2 disable-csma=no enable-nstreme=no enable-polling=yes framer-limit=3200 framer-policy=none
add bridge=bridge1 disabled=no edge=auto external-fdb=auto horizon=none interface=wlan1 path-cost=10 point-to-point=auto priority=0x80
add bridge=bridge1 disabled=no edge=auto external-fdb=auto horizon=none interface=wlan2 path-cost=10 point-to-point=auto priority=0x80
/interface bridge settings
set use-ip-firewall=no use-ip-firewall-for-pppoe=no use-ip-firewall-for-vlan=no
/interface l2tp-server server
set authentication=pap,chap,mschap1,mschap2 default-profile=default-encryption enabled=no max-mru=1460 max-mtu=1460 mrru=disabled
/interface ovpn-server server
set auth=sha1,md5 certificate=none cipher=blowfish128,aes128 default-profile=default enabled=no keepalive-timeout=60 mac-address=FE:66:CF:D3:D7:DB max-mtu=1500 \
    mode=ip netmask=24 port=1194 require-client-certificate=no
/interface pptp-server server
set authentication=mschap1,mschap2 default-profile=default-encryption enabled=no keepalive-timeout=30 max-mru=1460 max-mtu=1460 mrru=disabled
/interface sstp-server server
set authentication=pap,chap,mschap1,mschap2 certificate=none default-profile=default enabled=no keepalive-timeout=60 max-mru=1500 max-mtu=1500 mrru=disabled \
    port=443 verify-client-certificate=no
/interface wireless align
set active-mode=yes audio-max=-20 audio-min=-100 audio-monitor=00:00:00:00:00:00 filter-mac=00:00:00:00:00:00 frame-size=300 frames-per-second=25 receive-all=\
    no ssid-all=no
/interface wireless sniffer
set channel-time=200ms file-limit=10 file-name="" memory-limit=10 multiple-channels=no only-headers=no receive-errors=no streaming-enabled=no \
    streaming-max-rate=0 streaming-server=0.0.0.0
/interface wireless snooper
set channel-time=200ms multiple-channels=yes receive-errors=no
 ip address export
# oct/16/2011 13:41:38 by RouterOS 5.7
add address=10.0.0.24/24 disabled=no interface=bridge1 network=10.0.0.0
 ip firewall export
# oct/16/2011 13:43:04 by RouterOS 5.7
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s tcp-close-wait-timeout=10s tcp-established-timeout=1d tcp-fin-wait-timeout=10s \
    tcp-last-ack-timeout=10s tcp-syn-received-timeout=5s tcp-syn-sent-timeout=5s tcp-syncookie=no tcp-time-wait-timeout=10s udp-stream-timeout=3m udp-timeout=\
    10s
add action=passthrough chain=unused-hs-chain comment="place hotspot rules here" disabled=yes
add action=masquerade chain=srcnat disabled=no
add action=masquerade chain=srcnat comment="masquerade hotspot network" disabled=no src-address=10.0.0.0/24
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061 sip-direct-media=yes
set pptp disabled=no
 ip hotspot export
# oct/16/2011 13:43:46 by RouterOS 5.7
/ip hotspot profile
set default dns-name="" hotspot-address=0.0.0.0 html-directory=hotspot http-cookie-lifetime=3d http-proxy=0.0.0.0:0 login-by=cookie,http-chap name=default \
    rate-limit="" smtp-server=0.0.0.0 split-user-domain=no use-radius=no
add dns-name=wifi.egh.co.za hotspot-address=10.0.0.24 html-directory=hotspot http-cookie-lifetime=3d http-proxy=0.0.0.0:0 login-by=cookie,http-chap name=\
    hsprof1 nas-port-type=wireless-802.11 radius-accounting=yes radius-default-domain="" radius-interim-update=received radius-location-id="" \
    radius-location-name="" radius-mac-format=XX:XX:XX:XX:XX:XX rate-limit="" smtp-server=0.0.0.0 split-user-domain=no use-radius=yes
/ip hotspot
add address-pool=hs-pool-4 addresses-per-mac=2 disabled=no idle-timeout=5m interface=bridge1 keepalive-timeout=none name=hotspot1 profile=hsprof1
/ip hotspot user profile
set default idle-timeout=none keepalive-timeout=2m name=default shared-users=1 status-autorefresh=1m transparent-proxy=no
/ip hotspot ip-binding
add address=10.0.0.2 disabled=no type=bypassed
add address=10.0.0.5 disabled=no type=bypassed
add address=10.0.0.50 disabled=no type=bypassed
add address=127.0.0.1 disabled=no type=bypassed
add address=10.0.0.24 disabled=no type=bypassed
/ip hotspot service-port
/ip hotspot user
add disabled=no name=admin password="" profile=default
/ip hotspot walled-garden
add action=allow disabled=no dst-host=buzzconnect.dyndns.org*
add action=allow disabled=no dst-host=10.0.0.2 dst-port=53
/ip hotspot walled-garden ip
add action=accept disabled=no dst-host=10.0.0.2
Im using Radius Manager remotely through dyndns
Any help would greatly be appreciated
