no internet access to pc
Dear All ,
I have a situation ,and need your help plz
I have a mikrotik router version 6.18
the problem is I can access the server via remote desktop connection all work fine, but the server has no internet access means I can’t use browser either team viewer and so all pc on my network I disabled all firewall rules
but still no internet access
before it was fine .
any suggestion ?
thank you.
Can you ping 8.8.8.8 ?
Have you set any DNS-server.
Too little information to be able to give a clear answer.
Thank you for your reply.
I can’t ping 8.8.8.8 and i have a dns server set
And one more thing it said internet access in the network connection icon but nothing works .
Send NAT rules or send masquerade rules. That will be easy to understand your problem.
