I have a CRS125-24G-1S with the following setup
cisco (192.168.0.1) → mikrotik (192.168.0.3) → Internal network (192.168.0.0/24), → VLAN2 (192.168.100.0/24)
Vlan2 is tagged with vlanid 500 from an AP and cisco is my external gateway
I have setup dhcp for vlan2 in mikrotik and clients connecting to the AP get their ip’s correctly but they don’t have internet. DNS is working for them
This is my config
set [ find default-name=ether1 ] name=ether1-master-local
set [ find default-name=ether2 ] master-port=ether1-master-local name=ether2-slave-local
set [ find default-name=ether3 ] master-port=ether1-master-local name=ether3-slave-local
set [ find default-name=ether4 ] master-port=ether1-master-local name=ether4-slave-local
set [ find default-name=ether5 ] master-port=ether1-master-local name=ether5-slave-local
set [ find default-name=ether6 ] master-port=ether1-master-local name=ether6-slave-local
set [ find default-name=ether7 ] master-port=ether1-master-local name=ether7-slave-local
set [ find default-name=ether8 ] master-port=ether1-master-local name=ether8-slave-local
set [ find default-name=ether9 ] master-port=ether1-master-local name=ether9-slave-local
set [ find default-name=ether10 ] master-port=ether1-master-local name=ether10-slave-local
set [ find default-name=ether11 ] master-port=ether1-master-local name=ether11-slave-local
set [ find default-name=ether12 ] master-port=ether1-master-local name=ether12-slave-local
set [ find default-name=ether13 ] master-port=ether1-master-local name=ether13-slave-local
set [ find default-name=ether14 ] master-port=ether1-master-local name=ether14-slave-local
set [ find default-name=ether15 ] master-port=ether1-master-local name=ether15-slave-local
set [ find default-name=ether16 ] master-port=ether1-master-local name=ether16-slave-local
set [ find default-name=ether19 ] master-port=ether17
set [ find default-name=ether20 ] master-port=ether17
set [ find default-name=ether21 ] master-port=ether1-master-local name=ether21-slave-local
set [ find default-name=ether22 ] master-port=ether1-master-local name=ether22-slave-local
set [ find default-name=ether23 ] master-port=ether1-master-local name=ether23-slave-local
set [ find default-name=ether24 ] master-port=ether1-master-local name=ether24-slave-local
set [ find default-name=sfp1 ] master-port=ether1-master-local name=sfp1-slave-local
/interface vlan
add interface=ether1-master-local l2mtu=1584 name=vlan2 vlan-id=500
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=aes-128-cbc
add name=dhcp_pool3 ranges=192.168.100.2-192.168.100.254
add address-pool=dhcp_pool3 disabled=no interface=vlan2 name=dhcp2
/system logging action
add name=remotesyslog remote=192.168.0.40 src-address=192.168.0.3 target=remote
set enabled=yes
add address=192.168.0.3/24 comment=“added by setup” interface=ether1-master-local network=192.168.0.0
add address=192.168.100.1/24 interface=vlan2 network=192.168.100.0
add address=192.168.100.0/24 dns-server=192.168.0.3 gateway=192.168.100.1 netmask=24
set allow-remote-requests=yes servers=192.168.0.12,192.168.0.14
add comment=“added by setup” distance=1 gateway=192.168.0.1
any help on how to give internet access to the vlan will be appreciated
