Can I get some insight in configuring Guest Networks using wlan1 & wlan2 interface. I have no need for the wireless networks, so my thought is to use the two wireless interfaces for guest networks.
I’m a newb to MikroTik. This is my first post outside the beginner forum. I’m using a RB4011iGS+5HacQ2HnD with an sfp S-RJ01 interfaced to the ISP. The MikroTik is running RouterOS 7.19.2. I am using WinBox to make configuration changes.
I have modified very little from the default configuration. I’ve added to the defconf an Offbridge interface “comment=offbridge build” (thanks @anav) and three DHCP servers “comment=subnet build” on ethernet interfaces ether7, ether8 & ether9. All the wired interface appear to be working (i.e. provide access to the Internet). I did test the default wireless configuration to confirm they worked before removing them.
I have successfully configured the wlan1 & wlan2 interfaces for guest login “comment=guest wifi build”. Hosts connect and obtain an IP. The failure is no internet access.
I can see data traffic numbers on RX wlan1 interface (only wireless interface I can test) and on the guest-bridge but no TX data for both. I have focused my attention on the nat rule trying a number of configurations without success. I never see any bytes or packet in the rule.
The nat rule in this file is the last I tried. I’m thinking it is a rule configuration but that may be wrong.
# 2025-06-30 20:06:06 by RouterOS 7.19.2
# model = RB4011iGS+5HacQ2HnD
add admin-mac= auto-mac=no comment=defconf name=bridge
add comment="subnet build" name="bridge 70"
add comment="subnet build" name="bridge 80"
add comment="subnet build" name="bridge 90"
add comment="guest wifi build" name=guest-bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
comment="guest wifi build" country=canada disabled=no distance=indoors \
frequency=auto mode=ap-bridge ssid=Guest_RRS_2G wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=\
20/40/80mhz-XXXX comment="guest wifi build" country=canada disabled=no \
distance=indoors frequency=auto mode=ap-bridge ssid=Guest_RRS_5G \
set [ find default-name=ether10 ] comment="offbridge build" name=OFFBridge
/interface wireless manual-tx-power-table
set wlan1 comment="guest wifi build"
set wlan2 comment="guest wifi build"
/interface wireless nstreme
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk comment=\
"guest wifi build" mode=dynamic-keys supplicant-identity=MikroTik
add comment="guest wifi build" name=guest-pool ranges=\
192.168.100.200-192.168.100.254
add comment="subnet build" name="pool 70" ranges=\
192.168.70.200-192.168.70.254
add comment="subnet build" name="pool 80" ranges=\
192.168.80.200-192.168.80.254
add comment="subnet build" name="pool 90" ranges=\
192.168.90.200-192.168.90.254
add address-pool=default-dhcp interface=bridge name=defconf
add address-pool=guest-pool comment="guest wifi build" interface=guest-bridge \
name=guest-server
add address-pool="pool 70" comment="subnet build" interface="bridge 70" name=\
"server 70"
add address-pool="pool 80" comment="subnet build" interface="bridge 80" name=\
"server 80"
add address-pool="pool 90" comment="subnet build" interface="bridge 90" name=\
"server 90"
/port
set 0 name=serial0
set 1 name=serial1
/certificate settings
set builtin-trust-anchors=not-trusted
/disk settings
set auto-media-interface=bridge auto-media-sharing=yes auto-smb-sharing=yes
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge interface=ether1
add bridge="bridge 70" comment="subnet build" interface=ether7
add bridge="bridge 80" comment="subnet build" interface=ether8
add bridge="bridge 90" comment="subnet build" interface=ether9
add bridge=guest-bridge comment="guest wifi build" interface=wlan1
add bridge=guest-bridge interface=wlan2
add interface=sfp-sfpplus1 list=WAN
add comment="offbridge build" interface=OFFBridge list=LAN
add comment="subnet build" interface="bridge 70" list=LAN
add comment="subnet build" interface="bridge 80" list=LAN
add comment="subnet build" interface="bridge 90" list=LAN
192.168.88.0
add address=192.168.69.1/30 comment="offbridge build" interface=OFFBridge \
network=192.168.69.0
add address=192.168.100.1/24 comment="guest wifi build" interface=\
guest-bridge network=192.168.100.0
add address=192.168.70.1/24 comment="subnet build" interface="bridge 70" \
network=192.168.70.0
add address=192.168.80.1/24 comment="subnet build" interface="bridge 80" \
network=192.168.80.0
add address=192.168.90.1/24 comment="subnet build" interface="bridge 90" \
network=192.168.90.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add comment=defconf interface=sfp-sfpplus1
add address=192.168.70.0/24 comment="subnet build" dns-server=192.168.70.1 \
gateway=192.168.70.1
add address=192.168.80.0/24 comment="subnet build" dns-server=192.168.80.1 \
gateway=192.168.80.1
192.168.88.1
add address=192.168.90.0/24 comment="subnet build" dns-server=192.168.90.1 \
gateway=192.168.90.1
add address=192.168.100.0/24 comment="guest wifi build" dns-server=\
192.168.100.1 gateway=192.168.100.1
set allow-remote-requests=yes servers=149.112.120.20,149.112.121.20
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan type=A
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
add action=masquerade chain=srcnat comment="guest wifi build" out-interface=\
sfp-sfpplus1 src-address=192.168.100.0/24
/ip service
set ftp disabled=yes
set telnet disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" \
dst-port=33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
add action=fasttrack-connection chain=forward comment="defconf: fasttrack6" \
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/system clock
set time-zone-autodetect=no time-zone-name=America/Winnipeg
/system identity
set name=officerouter
/system leds
add interface=wlan1 leds="wlan1_signal1-led,wlan1_signal2-led,wlan1_signal3-le\
d,wlan1_signal4-led,wlan1_signal5-led" type=wireless-signal-strength
add interface=wlan1 leds=wlan1_tx-led type=interface-transmit
add interface=wlan1 leds=wlan1_rx-led type=interface-receive
/tool graphing interface
add interface=bridge
/tool graphing resource
add
/tool mac-server
/tool mac-server mac-winbox
