No internet access when connecting through AP
Hi all,
I am newbie and have little experience. However I would need help with my setup:
I have mikrotik routerboard and on ethernet 5 I have connected TP-Link router and disabled dhcp on it (to act as an wifi AP)
I have set dhcp server on bridge interface under which all my ports are and everything works fine until I try to connect through the TP-Link wifi.
Cellphones seems to have no problem to connect to wifi and can access the internet. However when I try to connect from WIN laptop (any/tried multiple) the status gets to connected - No internet access. The device gets some very wierd IP and no Default Gateway.
As I have set nothing special on the TP-Link other than disabling the dhcp, I think there must be some issue with my mikrotik settings.
Thanks in advance for any help!
Please find export compact below:
# mar/16/2020 15:45:48 by RouterOS 6.46.4
# software id = ES32-2GHJ
# model = RB750Gr3
# serial number = 8AFF0A487D34
add admin-mac=74:4D:28:05:6E:0B auto-mac=no comment=defconf name=bridge
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip hotspot profile
add address-pool=default-dhcp disabled=no interface=bridge name=defconf
    192.168.88.0
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router.lan
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
add action=drop chain=forward comment="defconf: drop invalid" connection-state=\
    invalid
    "defconf:  drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=\
    out,none out-interface-list=WAN
/ip ssh
set allow-none-crypto=yes forwarding-enabled=remote
/system clock
set time-zone-name=Europe/Bratislava
/tool mac-server
/tool mac-server mac-winbox
Make sure you connect TP-link to RB using LAN port on TP-link (WAN port is not the right one in this case).
:unamused: feeling so dumb rn…
