I have a RB 751G
I like to have 2 separate networks with there own WiFi Virtual AP.
From both networks I can't access internet Why?
I connect my DSL modem with IP 192.168.2.254 to ETHER1
This is what I have configured.
Set system identity
system identity set name=mt01
Add bridges
interface bridge add name=BR-LAN disabled=no
interface bridge add name=BR-GAST disabled=no
Turn on WLAN
interface wireless enable wlan1
Hide SSID wlan1 (mikrotik)
interface wireless set wlan1 hide-ssid=yes
Set wireless mode
interface wireless set mode=ap-bridge wlan1 band=2ghz-b/g/n ht-txchains=0,1 ht-rxchains=0,1
Add a security profile
interface wireless security-profile add name=LAN authentication-type=wpa2-psk unicast-ciphers=aes-ccm group-ciphers=aes-ccm wpa2-pre-shared-key=")(&Access&()" mode=dynamic-keys
interface wireless security-profile add name=GAST authentication-type=wpa2-psk unicast-ciphers=aes-ccm group-ciphers=aes-ccm wpa2-pre-shared-key=#@!Gast!@# mode=dynamic-keys
Set wireless channel
interface wireless set wlan1 channel-width=20/40mhz-ht-above
Set wirless protocol
interface wireless set wlan1 wireless-protocol=any
Add virtual-ap
interface wireless add master-interface=wlan1 ssid=LAN security-profile=LAN name=VAP-LAN disabled=no
interface wireless add master-interface=wlan1 ssid=GAST security-profile=GAST name=VAP-GAST disabled=no
Add ports to Bridge
interface bridge port add interface=ether2 bridge=BR-LAN disabled=no
interface bridge port add interface=ether3 bridge=BR-LAN disabled=no
interface bridge port add interface=ether4 bridge=BR-LAN disabled=no
interface bridge port add interface=VAP-LAN bridge=BR-LAN disabled=no
interface bridge port add interface=ether5 bridge=BR-GAST disabled=no
interface bridge port add interface=VAP-GAST bridge=BR-GAST disabled=no
IP toewijzen aan Ether1
ip address add address=192.168.2.1/24 interface=ether1
IP toewijzen aan Ether2
ip address add address=192.9.201.1/24 interface=ether2
IP toewijzen aan Ether5
ip address add address=192.9.202.1/24 interface=ether5
Set Ether speed 1GB/s
interface ethernet set ether1 speed=1Gbps
interface ethernet set ether2 speed=1Gbps
interface ethernet set ether3 speed=1Gbps
interface ethernet set ether4 speed=1Gbps
interface ethernet set ether5 speed=1Gbps
Add DHCP-Address-Pool
ip pool add name=LAN range=192.9.201.2-192.9.201.254
ip pool add name=GAST range=192.9.202.2-192.9.202.254
Add DHCP-Server BR-LAN
ip dhcp-server add interface=BR-LAN name=DCHP-LAN address-pool=LAN lease-time=3d disabled=no
ip dhcp-server network add address=192.9.201.0/24 dns-server=194.151.228.18 gateway=192.9.201.1 netmask=255.255.255.0
Add DHCP-Server BR-GAST
ip dhcp-server add interface=BR-GAST name=DCHP-GAST address-pool=GAST lease-time=3d disabled=no
ip dhcp-server network add address=192.9.202.0/24 dns-server=194.151.228.18 gateway=192.9.202.1 netmask=255.255.255.0
