No internet access
I just bought myself a house and to celebrate that I got fiber-connection I got myself a RB960PGS.
So my initial thought was to have the Mikrotik do everything for me.. Just connect it with sfp and then set it up for IPTV (could not get that to work, since my IPTV-provier wont let me know how they provide the IPTV. I called RouterBoard support and he haven’t tried it with my provider, so no luck there)
Back to the topic, I then changed my mind so I plugged in the media-distributor / modem(?) but when I plug in the mikrotik router with WAN on eth1 I cant get it to work. I have just tried doing the Quick Set, but it wont obtain IP. Now I have my computer plugged into the modem and it works fine, but any device that I plug into the mikrotik wont get access to internet. Im new to mikrotik but I know how google works but “I still haven’t found what Im looking for”. So you are my best and last resort.
So this is frustrating… I plugged in the old netgear router and let it do the auto configuration and the after that it works like a charm (My speed is as good as when I plug my pc straight to the modem, with low latency).
Its clearly something with the Mikrotik router that I dont know how to config, and the wiki and/or help that you can find online is not that good either. Can anyone help me out?
Please provide your config (export hide-sensitive).
Its clean. I tried a lot of guides that I found. But I could not get it to work so I reset the router and tried to do as little as possible to get it work… and for me that would have been the quick set.
# jan/02/1970 00:01:50 by RouterOS 6.45.3
# software id = VFJ6-WX6Z
# model = 960PGS
# serial number = AD8A0A75ED15
add admin-mac=74:4D:28:09:0**:** auto-mac=no comment=defconf name=bridge
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
add bridge=bridge comment=defconf interface=sfp1
add address=192.168.88.1/24 comment=defconf interface=ether2 network=\
    192.168.88.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=\
    ether1
set allow-remote-requests=yes
/ip dns static
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
/tool mac-server
/tool mac-server mac-winbox
what vlan does your ISP use for fibre?
The LAN IP address should be attached to the bridge interface=bridge not a member port (currently set to interface=ether2)
Do I really need to know that tho? Ive been away for a few days but from what I could read about my ISP (Bahnhof) they don’t really want to share that info. I can try and call them and see.
I will try that, thanks for helping out!
EDIT: Dream-scenario would be to get the IPTV to work through the mikrotik-router. But without the info needed from my IPTV-provider Im not sure if its even possible to figure out?
EDIT 2: I did not change anything and when I came back home after being away during the weekend it worked. I just need to get better latency and overall speed (currently 71Mbit/s down and 69Mbit/s up, 30ms with 100/100).
