No internet access
Hi, I have problem setting up my new Mikrotik mANTBox 2 12s.
I don't have internet access when connected to the home AP mode in Mikrotik.
PlEA
[admin@MikroTik] > export
1970-01-02 00:32:15 by RouterOS 7.15.3
software id = DELETED
model = RB911G-2HPnD
serial number = DELETED
add admin-mac= DELETED auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] antenna-gain=15 band=2ghz-b/g/n channel-width=20/40mhz-XX country=croatia disabled=no frequency=auto installation=outdoor mode=ap-bridge ssid=MikroTik-DB0361 wireless-protocol=802.11
add name=WAN
add name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=dynamic-keys supplicant-identity=MikroTik
/iot lora servers
add address=eu.mikrotik.thethings.industries name=TTN-EU protocol=UDP
add address=us.mikrotik.thethings.industries name=TTN-US protocol=UDP
add address=eu1.cloud.thethings.industries name="TTS Cloud (eu1)" protocol=UDP
add address=nam1.cloud.thethings.industries name="TTS Cloud (nam1)" protocol=UDP
add address=au1.cloud.thethings.industries name="TTS Cloud (au1)" protocol=UDP
add address=eu1.cloud.thethings.network name="TTN V3 (eu1)" protocol=UDP
add address=nam1.cloud.thethings.network name="TTN V3 (nam1)" protocol=UDP
add address=au1.cloud.thethings.network name="TTN V3 (au1)" protocol=UDP
add name=dhcp ranges=192.168.1.2-192.168.1.100
add address-pool=dhcp interface=bridge name=dhcp1
add bridge=bridge comment=defconf disabled=yes interface=ether1
add interface=ether1 list=WAN
add interface=bridge list=LAN
add address=192.168.1.1/24 interface=bridge network=192.168.1.0
/ip dhcp-client
add address=0.0.0.0/24 dns-server=0.0.0.0 gateway=0.0.0.0 netmask=24
add address=192.168.1.0/24 dns-server=192.168.1.1 gateway=192.168.1.1 netmask=24
/system note
set show-at-login=no
May I assume that the mANTBox should receive internet on ether1 via DHCP? If that’s the case, remove all DHCP server related configuration (/ip pool, /ip dhcp-server, /ip dhcp-server network). If the Mikrotik connects to the internet via the same port otherwise, just remove it from the bridge
Thanks, its working now. After fixing i discovered i had some problem with Poe cable. Thanks again
