No internet connection to LAN yet router connects
Hi all,
I have recently purchased an hEX router (RB750Gr3) and I’m having (noob) troubles configuring it. My home internet setup is as follows: I have a 5G FWA connection, my ISP installed a ZTE MC7010 on the roof acting as antenna and modem, from which I get an ethernet cable that is supposed to connect to the WAN port of the ISP provided router. I wish to get rid of the latter in favour of the hEX.
Connecting the router to the internet, starting from the default configuration of RouterOS version 7.13.4, was trivial: I just had to connect the cable from the ZTE antenna to port 1, create a VLAN with vlan-ID 1038 on ether1 as per the ISP recommendation and setup the DHCP client on the newly created vlan1 interface.
I can correctly ping, e.g. 8.8.8.8, from the router’s tool, however all LAN ports are not connected to the internet. Nothing suspicious comes up to my (very) beginner’s eyes, so I’m here for help. This is my configuration:
# 2024-03-03 11:06:00 by RouterOS 7.13.4
# software id = **ELIDED**
# model = RB750Gr3
# serial number = **ELIDED**
add admin-mac=**ELIDED** auto-mac=no comment=defconf name=bridge
/interface vlan
add interface=ether1 name=vlan1 vlan-id=1038
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip hotspot profile
add address-pool=default-dhcp interface=bridge lease-time=10m name=defconf
/port
set 0 name=serial0
    192.168.88.0
/ip dhcp-client
add comment=defconf interface=vlan1
    192.168.88.1
set allow-remote-requests=yes
/ip dns static
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
#error exporting "/ip/ssh" (timeout)
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" \
    dst-port=33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/system clock
set time-zone-name=Europe/Rome
/system note
set show-at-login=no
/tool mac-server
/tool mac-server mac-winbox
This is mostly the default configuration with the just the additions mentioned above. Did I make any obvious mistake?
Thanks a lot to anybody willing to help!
Put vlan1 into the WAN interface list.
@tangent
More explicitly, OP now has:
And should run:
add comment=myconf interface=vlan1 list=WAN
Is that right?
Sure, should work.
Yup, it is the active interface!
Thanks a lot! That was it! I did have the feeling it was something silly :unamused:
