the problem i have with my ISP:
speed becomes very slow TimeOuts when there are 2 internet Desktops at same time in a Switch.
The Modem has DHCP Snooping or something.
creates DNS and UTP errors when ping to google.com without bridge, IGMP works ok, utp fails.
1x Desktop works Ok.
the idea is to create a Bridge or Proxy… with RouterOS.
if i set RouterOS individually, No Bridge, both PCs have internet, but very slow., useless.
there is something wrong with the ISP modem, and is locked by the ISP company…
the manufacturer: Technicolor, refuses to give an unlocked Firmware “i should call my ISP.”
With RouterOS Bridge:
UltraVNC is working, i can see the other Desktop PC…ok.
but Only LAN-1 has Internet.
LAN-9 does Not.
don´t know what could be the problem…
why there is only internet in Lan-1 Not the other LAN in the bridge.
DNS is set Ok.
Bridge ARP Enabled, LAN-1 Internet becomes disabled if i change this.
Bridge NAT Out WAN Passthrough.
FireWall NAT srcnat WAN masquerade
Bridge has All LAN Ports joined, No WAN.
WAN: Ether1
DHCP Client for WAN, works Ok.
WAN DynamicIP 192.168.0.25/24
Bridge Address: 192.168.10.1/24 192.168.10.0
DHCP Server:
Address Pool: 192.168.10.2-192.168.10.254
