I’m running in a final problem to finish my setup, and after numerous attempts to get it to work I’m afraid I need some help.
So my setup is as follows:
I have 3 VLANS:
VLAN 10 = Main
VLAN 20 = IOT
VLAN 30 = Guest
I have a Mikrotik HAP Ac2 connected to my ISP router (and gets a static IP of 192.168.0.4)
Port 1 on my MT is WAN
Port 5 on my MT is a Trunk to my Ubiquiti AP which carries 2 SSID’s / 2 VLAN (10 & 20)
I have 3 virtual wifi’s configured on both wlan channels on my MT, each have their own VLAN. (10, 20, 30)
So far everything is working EXCEPT when I connect my computer via LAN 4 (VLAN 20)
My computer connects, gets the correct IP, but I get on the internet…
What am I doing wrong ??
# model = RBD52G-5HacD2HnD
# serial number = E5780FA00097
add admin-mac=DC:2C:6E:11:70:14 auto-mac=no comment=defconf name=bridge
add name=bridge_vlan10
add name=bridge_vlan20
add name=bridge_vlan30
set [ find default-name=ether1 ] name=ether1-WAN
set [ find default-name=ether2 ] name=ether2-MAIN
set [ find default-name=ether3 ] name=ether3-MAIN
set [ find default-name=ether4 ] name=ether4-IOT
set [ find default-name=ether5 ] name=ether5-Trunk
/interface vlan
add interface=ether4-IOT name=ether4_vlan20 vlan-id=20
add interface=ether5-Trunk name=vlan10-trunk vlan-id=10
add interface=ether5-Trunk name=vlan20-trunk vlan-id=20
set 1 default-vlan-id=10 vlan-header=always-strip vlan-mode=secure
set 2 default-vlan-id=10 vlan-header=always-strip vlan-mode=secure
set 3 default-vlan-id=20 vlan-header=always-strip vlan-mode=secure
add comment=defconf name=WAN
add comment=defconf name=LAN
add authentication-types=wpa2-psk eap-methods="" mode=dynamic-keys name=\
secprof_main supplicant-identity=""
secprof_iot supplicant-identity=""
secprof_guest supplicant-identity=""
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n disabled=no distance=indoors \
frequency=2437 hide-ssid=yes installation=indoor mode=ap-bridge \
security-profile=secprof_main ssid=MikroTik-117018 wireless-protocol=\
802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=\
20/40/80mhz-XXXX disabled=no distance=indoors frequency=auto hide-ssid=\
yes installation=indoor mode=ap-bridge security-profile=secprof_main \
ssid=MikroTik-117019 wireless-protocol=802.11
add disabled=no keepalive-frames=disabled mac-address=02:00:00:AA:00:04 \
master-interface=wlan1 multicast-buffering=disabled name=wl1_guest \
security-profile=secprof_guest ssid=LTS39--MT-Guest vlan-id=30 vlan-mode=\
use-tag wds-cost-range=0 wds-default-cost=0 wps-mode=disabled
add disabled=no keepalive-frames=disabled mac-address=02:00:00:AA:00:01 \
master-interface=wlan1 multicast-buffering=disabled name=wl1_iot \
security-profile=secprof_iot ssid=LTS39--MT-IoT vlan-id=20 vlan-mode=\
add disabled=no keepalive-frames=disabled mac-address=02:00:00:AA:00:02 \
master-interface=wlan1 multicast-buffering=disabled name=wl1_main \
security-profile=secprof_main ssid=LTS39--MT-Main vlan-id=10 vlan-mode=\
add disabled=no keepalive-frames=disabled mac-address=02:00:00:AA:00:03 \
master-interface=wlan2 multicast-buffering=disabled name=wl2_guest ssid=\
LTS39--MT-Guest vlan-id=30 vlan-mode=use-tag wds-cost-range=0 \
add disabled=no keepalive-frames=disabled mac-address=DE:2C:6E:11:70:1B \
master-interface=wlan2 multicast-buffering=disabled name=wl2_iot \
add disabled=no keepalive-frames=disabled mac-address=02:00:00:AA:00:00 \
master-interface=wlan2 multicast-buffering=disabled name=wl2_main \
/interface vlan
add interface=wl1_main name=wl1_vlan10 vlan-id=10
add interface=wl1_iot name=wl1_vlan20 vlan-id=20
add interface=wl1_guest name=wl1_vlan30 vlan-id=30
add interface=wl2_main name=wl2_vlan10 vlan-id=10
add interface=wl2_iot name=wl2_vlan20 vlan-id=20
add interface=wl2_guest name=wl2_vlan30 vlan-id=30
/ip hotspot profile
add name=pool_trunk10 ranges=10.10.10.50-10.10.10.100
add name=pool_trunk20 ranges=20.20.20.50-20.20.20.100
add name=pool_main ranges=10.10.10.50-10.10.10.100
add name=pool_iot ranges=20.20.20.50-20.20.20.100
add name=pool_guest ranges=30.30.30.50-30.30.30.100
add address-pool=default-dhcp interface=bridge name=defconf
add address-pool=pool_trunk20 interface=vlan20-trunk name=dhcp_trunk20
add address-pool=pool_trunk10 interface=vlan10-trunk name=dhcp_trunk10
add address-pool=pool_main interface=bridge_vlan10 name=dhcp_main
add address-pool=pool_iot interface=bridge_vlan20 name=dhcp_iot
add address-pool=pool_guest interface=bridge_vlan30 name=dhcp_guest
add bridge=bridge_vlan10 interface=ether2-MAIN pvid=10
add bridge=bridge_vlan10 interface=ether3-MAIN
add bridge=bridge interface=ether5-Trunk
add bridge=bridge_vlan10 interface=wl1_main
add bridge=bridge_vlan10 interface=wl1_vlan10
add bridge=bridge_vlan10 interface=wl2_main
add bridge=bridge_vlan10 interface=wl2_vlan10
add bridge=bridge_vlan20 interface=wl1_iot
add bridge=bridge_vlan20 interface=wl1_vlan20
add bridge=bridge_vlan20 interface=wl2_iot
add bridge=bridge_vlan20 interface=wl2_vlan20
add bridge=bridge_vlan30 interface=wl1_guest
add bridge=bridge_vlan30 interface=wl1_vlan30
add bridge=bridge_vlan30 interface=wl2_guest
add bridge=bridge_vlan30 interface=wl2_vlan30
add bridge=bridge_vlan20 interface=ether4-IOT
add bridge=bridge_vlan20 interface=ether4_vlan20
add independent-learning=no ports=ether4-IOT switch=switch1 vlan-id=20
add independent-learning=no ports=ether2-MAIN,ether3-MAIN switch=switch1 \
vlan-id=10
add comment=defconf interface=ether1-WAN list=WAN
add address=192.168.88.1/24 interface=bridge network=192.168.88.0
add address=10.10.10.1/24 interface=vlan10-trunk network=10.10.10.0
add address=20.20.20.1/24 interface=vlan20-trunk network=20.20.20.0
add address=10.10.10.1/24 interface=bridge_vlan10 network=10.10.10.0
add address=20.20.20.1/24 interface=bridge_vlan20 network=20.20.20.0
add address=30.30.30.1/24 interface=bridge_vlan30 network=30.30.30.0
/ip dhcp-client
add address=10.10.10.0/24 dns-server=8.8.8.8 gateway=10.10.10.1
add address=20.20.20.0/24 dns-server=8.8.8.8 gateway=20.20.20.1
add address=30.30.30.0/24 dns-server=8.8.8.8 gateway=30.30.30.1
add address=192.168.88.0/24 dns-server=192.168.88.1 gateway=192.168.88.1
set allow-remote-requests=yes
/ip dns static
established,related,untracked
invalid
disabled=yes in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
add action=masquerade chain=srcnat comment="defconf: masquerade" disabled=yes \
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/system clock
set time-zone-name=Europe/Brussels
/system routerboard settings
set cpu-frequency=auto
/tool mac-server
/tool mac-server mac-winbox
