Hi
Im fairly new to this byt the system has been working for quite some time.
After my internet provider hade som problems in my city I had to reboot my Router.
After this i do get internet via Ethernet cable but my Waps dont give me access to internet via WiFi.
Can anyone please help.
Setup is
RB-750
Wap
Wap
And from terminal i copyed:
MMM MMM KKK TTTTTTTTTTT KKK
MMMM MMMM KKK TTTTTTTTTTT KKK
MMM MMMM MMM III KKK KKK RRRRRR OOOOOO TTT III KKK KKK
MMM MM MMM III KKKKK RRR RRR OOO OOO TTT III KKKKK
MMM MMM III KKK KKK RRRRRR OOO OOO TTT III KKK KKK
MMM MMM III KKK KKK RRR RRR OOOOOO TTT III KKK KKK
MikroTik RouterOS 6.43 (c) 1999-2018 http://www.mikrotik.com/
[?] Gives the list of available commands
command [?] Gives help on the command and list of arguments
[Tab] Completes the command/word. If the input is ambiguous,
a second [Tab] gives possible options
/ Move up to base level
.. Move up one level
/command Use command at the base level
jan/02/1970 00:00:13 system,error,critical router was rebooted without proper shut
down
oct/05/2018 21:58:09 system,error,critical router was rebooted without proper shut
down
oct/05/2018 22:32:30 system,error,critical login failure for user from 192.168.88
.244 via winbox
[admin@MikroTik] > /Export
expected command name (line 1 column 2)
[admin@MikroTik] > /export
oct/05/2018 22:33:26 by RouterOS 6.43
software id = Q5NH-78BL
model = RouterBOARD 750G r2
serial number = 5C1305CF0F03
add admin-mac=E4:8D:8C:AF:F4:C8 auto-mac=no comment=defconf name=bridge
add comment=defconf name=WAN
add comment=defconf name=LAN
add address-pool=default-dhcp disabled=no interface=bridge name=defconf
/caps-man manager interface
set [ find default=yes ] forbid=yes
add disabled=no interface=bridge
add address=192.168.88.1/24 comment=defconf interface=bridge network=
192.168.88.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=ether1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router.lan
add action=accept chain=input comment=
"defconf: accept established,related,untracked" connection-state=
add action=drop chain=input comment="defconf: drop invalid" connection-state=
invalid
add action=drop chain=input comment="defconf: drop all not coming from LAN"
in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept in ipsec policy"
ipsec-policy=in,ipsec
add action=accept chain=forward comment="defconf: accept out ipsec policy"
ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment="defconf: fasttrack"
"defconf: accept established,related, untracked" connection-state=
add action=drop chain=forward comment="defconf: drop invalid" connection-state=
invalid
"defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=
out,none out-interface-list=WAN
/ipv6 firewall address-list
add address=::224.0.0.0/100 comment="defconf: other" list=bad_ipv6
add address=::127.0.0.0/104 comment="defconf: other" list=bad_ipv6
add address=::/104 comment="defconf: other" list=bad_ipv6
add address=::255.0.0.0/104 comment="defconf: other" list=bad_ipv6
/ipv6 firewall filter
invalid
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=
33434-33534 protocol=udp
"defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=
udp src-address=fe80::/16
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500
protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=
ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=
ipsec-esp
"defconf: drop everything else not coming from LAN" in-interface-list=!LAN
invalid
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6"
src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6"
dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1"
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=
icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500
protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=
ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=
ipsec-esp
/system clock
set time-zone-name=Europe/Stockholm
/system routerboard settings
set silent-boot=no
/tool mac-server
/tool mac-server mac-winbox
[admin@MikroTik] >
