No Internet when Lan Ip and dhcp is changed
If I change my lan ip from
192.168.88.1/24 to 192.168.1.1/24
and dhcp range from
192.168.88.10-192.168.88.254 to 192.168.1.20-192.168.1.199
it ends up with no internet connection?
I used the quick set to make the changes version 5.19 and the device is RB751U-2HnD
/Buck
Update:
It seems that the DNS is stuck on the old one 192.168.88.1 and that’s what’s causing the problem. I changed it to 8.8.8.8 and then it works :smiley:
I think it would be nice if it changed when router IP is changed or at least it could be managed on the “Quick set” page
/Buck
