no internet
I have setup a RB751 with two pppoe dial ups to my isp through a bridged modem. This part is working fine.
Ether 2 is the dhcp server which is connected to my pc’s. Here is the problem:
  1. PC’s cannot ping the gateway or get internet
  2. The router can ping the gateway and also has internet.
What could be the issue? Please advise
Go to “new terminal” and type “export”
Copy and paste the result on this forum
So we can see what going on.
Here it is:
set [ find default-name=ether1 ] disabled=yes name=ether1-gateway
set [ find default-name=ether2 ] name=ether2-master-local
set [ find default-name=ether3 ] name=ether3-slave-local
set [ find default-name=ether4 ] name=ether4-slave-local
set [ find default-name=ether5 ] name=ether5-slave-local
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-ht-above
distance=indoors l2mtu=2290 mode=ap-bridge ssid=MikroTik-FBDB8B
/ip neighbor discovery
set ether1-gateway discover=no
add name=dhcp_pool2 ranges=192.168.16.71-192.168.16.254
add address-pool=dhcp_pool2 disabled=no interface=ether2-master-local name=
dhcp1
/interface pppoe-client
add ac-name="" add-default-route=yes allow=pap,chap,mschap1,mschap2
default-route-distance=1 dial-on-demand=no disabled=no interface=
ether4-slave-local keepalive-timeout=60 max-mru=1480 max-mtu=1480 mrru=1600
name="ether4 pppoe" password=Zxxpqa@2 profile=default service-name=""
use-peer-dns=yes user=xxxxxxxxxxxxx
ether5-slave-local keepalive-timeout=60 max-mru=1480 max-mtu=1480 mrru=1600
name="ether5 pppoe" password=mxcmngkm profile=default service-name=""
add address=192.168.16.70/32 interface=ether2-master-local network=
192.168.16.70
add address=192.168.16.0/24 gateway=192.168.16.70
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router
/ip firewall address-list
add address=192.168.16.0/24 list=LAN
add action=masquerade chain=srcnat out-interface=ether5-slave-local
add action=masquerade chain=srcnat out-interface=ether2-master-local
ether4 pppoe not ready
add action=masquerade chain=srcnat out-interface="ether4 pppoe"
add distance=1 gateway="ether5 pppoe"
add distance=1 gateway="ether4 pppoe"
add distance=1 dst-address=192.168.16.0/24 gateway=ether2-master-local
/ip upnp
set allow-disable-external-interface=no
/system lcd
set contrast=0 enabled=no port=parallel type=24x4
/system lcd page
set time disabled=yes display-time=5s
set resources disabled=yes display-time=5s
set uptime disabled=yes display-time=5s
set packets disabled=yes display-time=5s
set bits disabled=yes display-time=5s
set version disabled=yes display-time=5s
set identity disabled=yes display-time=5s
set "ether5 pppoe" disabled=yes display-time=5s
set "ether4 pppoe" disabled=yes display-time=5s
set wlan1 disabled=yes display-time=5s
set ether1-gateway disabled=yes display-time=5s
set ether2-master-local disabled=yes display-time=5s
set ether3-slave-local disabled=yes display-time=5s
set ether4-slave-local disabled=yes display-time=5s
set ether5-slave-local disabled=yes display-time=5s
/system leds
set 0 interface=wlan1
/tool mac-server
add interface=ether2-master-local
add interface=ether3-slave-local
add interface=ether4-slave-local
add interface=ether5-slave-local
add interface=wlan1
add
/tool mac-server mac-winbox
add interface=wlan1
Geef meer uitleg over wat je precies wil
Give more explanation what you realy want.
Welke interfaces hoort bij wat bijvoorbeeld?
For example, the interfaces corresponds to what?
Ik gebruik in dit geval steeds bridges.
I use bridges in this case
PPPOE kan ik niet uitproberen
I can’t try out PPPOE
Ether 2 vanwaar moet die zijn internet nemen? van al de PPPOE interfaces?
Mail me op info@wirelessinfo.be
This is how i want it to work:
  • ether 2 is acting as the dhcp server
  • ether 4&5 are pppoe dial outs to my isps for internet
  • i want the internet to go through ether 2 to all my pc’s
all the internet for ether 2 must come from the ppp
Reset the routerboard
Copy and paste this in “new terminal” try this configuration
CAUTION!!! edit passwords the are visible by export
add l2mtu=1598 name=bridge-ether4
add l2mtu=1598 name=bridge-ether5
/interface wireless
set [ find default-name=wlan1 ] l2mtu=1600
add name=dhcp_pool1 ranges=192.168.16.71-192.168.16.254
add address-pool=dhcp_pool1 disabled=no interface=ether2-master-local name=
dhcp1
add ac-name=“” add-default-route=yes allow=pap,chap,mschap1,mschap2
bridge-ether4 keepalive-timeout=60 max-mru=1480 max-mtu=1480 mrru=1600
name=“ether4 pppoe” password=Zxxpqa@2 profile=default service-name=“”
bridge-ether5 keepalive-timeout=60 max-mru=1480 max-mtu=1480 mrru=1600
name=“ether5 pppoe” password=mxcmngkm profile=default service-name=“”
add bridge=bridge-ether5 interface=ether5-slave-local
add bridge=bridge-ether4 interface=ether4-slave-local
add address=192.168.16.70/24 interface=ether2-master-local network=
192.168.16.0
add address=192.168.16.0/24 dns-server=8.8.8.8,8.8.4.4 gateway=192.168.16.70
/ip dns static
add action=masquerade chain=srcnat out-interface=bridge-ether5 src-address=
192.168.16.0/24
add action=masquerade chain=srcnat disabled=yes out-interface=
ether2-master-local
add action=masquerade chain=srcnat out-interface=bridge-ether4 src-address=
192.168.16.0/24
add distance=1 gateway=“ether5 pppoe”
add distance=1 gateway=“ether4 pppoe”
/ip upnp
/system leds
/tool mac-server
add interface=wlan1
i have used the config but still cannot get internet access on the pc. I can ping the gateway but not 8.8.8.8.
There is internet on the router.
Look if the pppoe is connected and established
I can’t test the pppoe, see if password is correct
The pppoe is connected and traffic is flowing.
I notice under NAT there are no bytes or packets
Try this
Don’t forget reset without default configuration.
add l2mtu=1598 name=bridge-local
/interface wireless
add address-pool=dhcp_pool1 disabled=no interface=brid
add bridge=bridge-local interface=ether3-slave-local
add bridge=bridge-local interface=ether2-master-local
add address=192.168.16.70/24 interface=bridge-local ne
add address=192.168.16.0/24 dns-server=192.168.16.70,8
192.168.16.70
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
/ip dns static
add address=192.168.16.70 name=router
192.168.16.0/24
ether2-master-local
192.168.16.0/24
/ip upnp
/system leds
/tool mac-server
add interface=wlan1
Still no luck, can ping gateway but no internet
Can you change in NAT the out interface to the ppoe interface
Thanks, it seems to be working now. . .will test it further, thanks for all the help!
Is there a way to load balance the traffic from the two pppoe? At the moment it is only using the one for traffic.
