Hi all,
I’m very aware, that there are several topics on the forum covering this subject, but I have been trawling around for days now, trying to find the solution.
I have 2 idenditical RB1100, with more or less identical setups. Biggest diffenrence is that the well working remote conf. doesn’t act DHCP-server, however my local RB make me go crazy about this ussue.
Problem: When I succesfully connect to the router from a L2TP client, I can only ping the LAN adress (192.168.4.1) of the router - no other client on this subnet (192.168.4.0/24).
I’m pooling with a different subnet (192.168.5.0/24) for the remote clients. I have tried to disable all drop rules in the firewall in order to discover a firewall blocking. I have tried to ajust the ARP. I have tried different /IP Route settings from the pool subnet. Nothing helps me. Now I have only your expertise to stick to…so I really hope some of you guys can see what wrong.
My conf below: (deleted my public IP’s)
# 2023-08-30 18:46:21 by RouterOS 7.11
# software id = GWV4-RIQA
# model = RB1100Dx4
# serial number = 9BD80Axxxxxxx
add arp=proxy-arp name=LAN-bridge
set [ find default-name=ether1 ] name=ether1_WAN-port
/interface l2tp-server
add name=l2tp-VPN user=MA_VPN
/disk
set sata1 type=hardware
add parent=sata1 partition-number=1 partition-offset=512 partition-size=\
"64 017 353 728" type=partition
add name=WAN
add name=LAN
/ip ipsec profile
set [ find default=yes ] dh-group=modp1024 enc-algorithm=aes-256 \
hash-algorithm=sha256
add dh-group=modp2048 enc-algorithm=aes-256 hash-algorithm=sha512 name=\
G-MA
/ip ipsec peer
add address="remote-public-ip"/32 exchange-mode=ike2 name=G-MA profile=\
G-MA
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=sha256,sha1 enc-algorithms=\
aes-256-cbc,aes-128-cbc
add auth-algorithms=sha512 enc-algorithms=aes-256-cbc name=IKEv2-proposal \
pfs-group=none
add name=dhcp_pool1 ranges=192.168.4.80-192.168.4.199
add add-arp=yes address-pool=dhcp_pool1 interface=LAN-bridge name=DHCP
/port
set 0 name=serial0
set 1 name=serial1
/ppp profile
add bridge=LAN-bridge local-address=192.168.4.1 name=MA_VPN
add bridge=LAN-bridge interface=ether2
add bridge=LAN-bridge interface=ether3
add bridge=LAN-bridge interface=ether4
add bridge=LAN-bridge interface=ether5
add bridge=LAN-bridge interface=ether6
add bridge=LAN-bridge interface=ether7
add bridge=LAN-bridge interface=ether8
add bridge=LAN-bridge interface=ether9
add bridge=LAN-bridge interface=ether10
add bridge=LAN-bridge interface=ether11
add bridge=LAN-bridge interface=ether12
add bridge=LAN-bridge interface=ether13
/interface detect-internet
set detect-interface-list=all internet-interface-list=WAN lan-interface-list=\
LAN wan-interface-list=WAN
/interface l2tp-server server
set authentication=mschap1,mschap2 default-profile=MA_VPN enabled=yes \
use-ipsec=yes
add interface=ether1_WAN-port list=WAN
add interface=LAN-bridge list=LAN
add address=192.168.4.1/24 interface=LAN-bridge network=192.168.4.0
/ip dhcp-client
add interface=ether1_WAN-port use-peer-dns=no
/ip dhcp-server lease
add address=192.168.4.100 mac-address=2C:56:DC:DC:31:BD
add address=192.168.4.99 mac-address=80:A5:89:9E:00:00
add address=192.168.4.101 mac-address=80:A5:89:9E:6C:06
add address=192.168.4.111 allow-dual-stack-queue=no mac-address=\
2C:56:DC:DD:4B:ED
add address=192.168.4.0/24 dns-server=8.8.8.8,8.8.4.4,1.1.1.1,1.0.0.1 \
gateway=192.168.4.1 netmask=24
set servers=8.8.8.8,8.8.4.4,1.1.1.1,1.0.0.1
/ip firewall address-list
add address=192.168.4.0/24 list=MA_LAN
add address=192.168.7.0/24 list=G_LAN
add address=192.168.4.0/24 list=allowed_to_router
add address=192.168.7.0/24 list=allowed_to_router
add address="remote-public-gateway-ip" list=allowed_to_router
add address="local-public-ip" list=allowed_to_router
add address=0.0.0.0/8 comment=RFC6890 list=not_in_internet
add address=172.16.0.0/12 comment=RFC6890 list=not_in_internet
add address=192.168.0.0/16 comment=RFC6890 list=not_in_internet
add address=10.0.0.0/8 comment=RFC6890 list=not_in_internet
add address=169.254.0.0/16 comment=RFC6890 list=not_in_internet
add address=127.0.0.0/8 comment=RFC6890 list=not_in_internet
add address=224.0.0.0/4 comment=Multicast list=not_in_internet
add address=198.18.0.0/15 comment=RFC6890 list=not_in_internet
add address=192.0.0.0/24 comment=RFC6890 list=not_in_internet
add address=192.0.2.0/24 comment=RFC6890 list=not_in_internet
add address=198.51.100.0/24 comment=RFC6890 list=not_in_internet
add address=203.0.113.0/24 comment=RFC6890 list=not_in_internet
add address=100.64.0.0/10 comment=RFC6890 list=not_in_internet
add address=240.0.0.0/4 comment=RFC6890 list=not_in_internet
add address=192.88.99.0/24 comment="6to4 relay Anycast [RFC 3068]" list=\
not_in_internet
add address=192.168.8.0/24 list=allowed_to_router
add address=192.168.5.0/24 list=allowed_to_router
add address=192.168.7.0/24 list=LAN_IP
add address=192.168.4.0/24 list=LAN_IP
add address=192.168.5.0/24 list=LAN_IP
add address=192.168.8.0/24 list=LAN_IP
add address="remote-public-gateway-ip" list=WAN_IP
add address="local-public-ip" list=WAN_IP
established,related,untracked
add action=drop chain=input comment="defconf: drop invalid packets" \
connection-state=invalid
add action=accept chain=input comment="defconf: accept ICMP (ping)" protocol=\
icmp
add action=accept chain=input comment="VPN - Accept IPsec-esp" \
in-interface=ether1_WAN-port protocol=ipsec-esp
"VPN - Accept input IPsec, L2TP, VPN" dst-port=500,1701,4500 \
in-interface=ether1_WAN-port protocol=udp
add action=accept chain=input comment="Accept Local LAN" src-address-list=\
LAN_IP
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment=\
"defconf: fastrack - establihed, related" connection-state=\
established,related hw-offload=yes
connection-state=invalid log=yes log-prefix=invalid
"Drop tries to reach not public addresses from LAN" dst-address-list=\
not_in_internet in-interface=LAN-bridge log=yes log-prefix=\
!public_from_LAN out-interface=!LAN-bridge
"Drop incoming packets that are not NAT`ted" connection-nat-state=!dstnat \
connection-state=new in-interface-list=WAN log=yes log-prefix=!NAT
add action=jump chain=forward comment="jump to ICMP filters" jump-target=icmp \
protocol=icmp
"Drop incoming from internet which is not public IP" in-interface=\
ether1_WAN-port log=yes log-prefix=!public src-address-list=\
not_in_internet
"Drop packets from LAN that do not have LAN IP" in-interface=LAN-bridge \
log=yes log-prefix=LAN_!LAN src-address-list=!LAN_IP
add action=accept chain=icmp comment="echo reply" icmp-options=0:0 protocol=\
icmp
add action=accept chain=icmp comment="net unreachable" icmp-options=3:0 \
protocol=icmp
add action=accept chain=icmp comment="host unreachable" icmp-options=3:1 \
protocol=icmp
add action=accept chain=icmp comment=\
"host unreachable fragmentation required" icmp-options=3:4 protocol=icmp
add action=accept chain=icmp comment="allow echo request" icmp-options=8:0 \
protocol=icmp
add action=accept chain=icmp comment="allow time exceed" icmp-options=11:0 \
protocol=icmp
add action=accept chain=icmp comment="allow parameter bad" icmp-options=12:0 \
protocol=icmp
add action=drop chain=icmp comment="deny all other types"
add action=accept chain=srcnat dst-address-list=G_LAN src-address-list=\
MA_LAN
add action=accept chain=dstnat dst-address-list=MA_LAN src-address-list=\
G_LAN
add action=masquerade chain=srcnat ipsec-policy=out,none out-interface-list=\
WAN
add action=dst-nat chain=dstnat comment="CV forward" dst-port=\
108,1554,8010 in-interface-list=WAN protocol=tcp to-addresses=\
192.168.4.50
/ip ipsec identity
add comment="G-MA key" peer=G-MA
/ip ipsec policy
add dst-address=192.168.7.0/24 peer=G-MA proposal=IKEv2-proposal \
src-address=192.168.4.0/24 tunnel=yes
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www port=8080
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/ppp secret
add name=MA_VPN profile=MA_VPN
/system clock
set time-zone-name=Europe/Copenhagen
/system note
set show-at-login=no
/system ntp client
set enabled=yes
/system ntp client servers
add address=dk.pool.ntp.org
Many thanks in advance for helping me out - I’m truly gratefull
