No link between CRS305 and Media-Converter
I see no connectivity when I try to connect the CRS305 to my media converter in port SFP2 and don’t understand why. The SFP modules I use seem to be recognized, but no traffic is coming through.
Setup
Observations:
  • The connection between the media converter and my endpoint (laptop) seems fine (ethernet lights blinking up on both ends).
  • The “link” light on the media converter is not lit up
  • I tried using the following media converter also, but that didn’t work either: https://www.fs.com/de/products/104627.html
Equiment:
Is there some setting on the CRS that needs changing?
Any help appreciated!
You probably need to disable autonegotiation on the CRS SFP interface Ethernet tab, and manually set it to 1Gbps + full duplex as that’s what the MC220L supports.
