No Link on RouterBOARD 750G
I was given a RouterBOARD 750G that I am trying to setup. I followed the reset instructions (hold down the reset button until the act light blinks) - however when I plug into a ethernet port I do not get link on any of the interfaces regardless of if I am using a straight through or cross over cable.
Where do I go from here?
Thanks!
Don’t conncet on ether1 if the routerboard has the default settings.
Connect with ether2 to 5
If that not helps follow the netinstall procedure that i made
http://www.wirelessinfo.be/index.php/mikrotik/pages/netinstalle
Thanks - that would make a big difference. I’ll try your fixes tomorrow.
Let me know.
