No local website on MT?
I had recently setup a new MT router and put it in production. I wanted to enable graphing and have realized the local webpage with the links to the graphing and the webbox login are missing. The page is just blank.
If I type the page into the Firefox, it just shows a blank page and show source does not show anything.
I show all this under file
0 supout.rif .rif file 140742 sep/11/2006 15:40:54
1 console-dump.txt .txt file 4787 sep/07/2006 17:59:52
2 hotspot directory aug/11/2006 18:04:17
3 hotspot/lv directory aug/11/2006 18:04:17
4 hotspot/lv/status.html .html file 2760 aug/11/2006 18:04:17
5 hotspot/lv/errors.txt .txt file 3749 aug/11/2006 18:04:17
6 hotspot/lv/radvert.html .html file 1475 aug/11/2006 18:04:17
7 hotspot/lv/login.html .html file 3408 aug/11/2006 18:04:17
8 hotspot/lv/logout.html .html file 1843 aug/11/2006 18:04:17
9 hotspot/lv/alogin.html .html file 1303 aug/11/2006 18:04:17
10 hotspot/img directory aug/11/2006 18:04:17
11 hotspot/img/logobottom.png .png file 4317 aug/11/2006 18:04:17
12 hotspot/status.html .html file 3107 aug/11/2006 18:04:17
13 hotspot/md5.js .js file 7218 aug/11/2006 18:04:17
14 hotspot/redirect.html .html file 213 aug/11/2006 18:04:17
15 hotspot/errors.txt .txt file 3615 aug/11/2006 18:04:17
16 hotspot/radvert.html .html file 1481 aug/11/2006 18:04:17
17 hotspot/login.html .html file 3384 aug/11/2006 18:04:17
18 hotspot/logout.html .html file 1813 aug/11/2006 18:04:17
19 hotspot/alogin.html .html file 1293 aug/11/2006 18:04:17
20 hotspot/error.html .html file 898 aug/11/2006 18:04:
Running version 2.9.30
Any ideas?
check www service port in /ip services and if it’s enabled at all. also check firewall
