No log from Hotspot
Hallo @all
I want to use Walled Garden to restrict the Gateway only to Google Play store and Apples iTunes app.
I have configure them with the test Domain “*.heise.de” and it works perfect. I can open the side without a Login. Now i have add .gogle.com, but it don’t work. I found also some fdqn for the Google Play store. They also don’t work.
Then i add "
" at the config. Now all domains are accepted and have Access to all. To know how the hotspot is working i add the hotspot to the System log. Now i open the side, the Counter incerements but i don’t see anythink at the log.
My question is why i don’t see somethink in the log file?
RouterOS 6.34.4
Peter
you should open ip in walled garden IP
