No luck with Compex WLE600v5-23
Testing the Compex WLE600v5-23 on RB912UAG-2HPnD yields strange results. The RB912 finds the Compex card, but it doesnt seem to work. I.e. in wireless scan it sees other access points (not 802.11ac) but doesnt seem to radiate any power. In the Tx power tab all figures are “0”.
Is this a compatibility issue with the Compex card?
-DG
Did you verify this is a v2 card? (QCA9882-AR4x)
Did you connect the 5v pin to a 5v powersource? As I read on the site this is mandatory.
Can you put here a link where have you found information about that 5V pin?
It’s from the datasheet on the compex site.
THX
Now I see it: "Customers have to connect a 5V power supply to the pin on WLE900N5-23. "
