no more than one link between same elements
I have two routers which have 3 wireless point to point links between them. The three links are load balanced via OSPF. If I try to add more than one link between the routers in the Dude, I get “no more than one link between same elements” error.
Is there a away to get around this issue so I can see the utilization on all three links? If not is this something on the road map for down the road?
Thanks,
Eric
Add 3 static objects to link to then back to the other router.
router static static static router
/–s–
R—s—R
--s–/
HTH,
Lebowski
Note adding a static will crash the dude 4.2. Copy a different static object or find the one in this board to paste…
Note2 the ascii art is broke :slight_smile:
Thanks for the advice. Not sure why I didn’t think of doing it this way. I ended up adding three networks and then linking each of the ports on the routers into the three subnets from both sides.
