wifiwave2 package for 802.11ax (WiFI6) hardware is not made by MikroTik anymore, it uses the Qualcomm driver from chip manufacturer. You get much faster support for new chips, increased speed, a lot of new protocols, and possibly even much faster time to WiFi7 adoption. In turn, you lose some MikroTik custom made toys. Some of them we try to bring back, some of that is not possible. And also, some functions are not even supported by new chips themselves.
We do keep working on the new package and some things are coming back (like CAPsMAN etc).
Lack of spectral scan is not related to wave2 but because Mikrotik started using cheapest grade of 802.11ac/ax chips that doesn’t support that feature.
Just look what’s Ubiquity doing with exactly same radio chipset with advanced features enabled: Spectrum scans, QAM constellation views, TDMA, …
As for wifi2, it’s sad to see these are basically SOHO grade locked down drivers, with limited options comparable to what you get on any home AP.
I think this is the main reason we haven’t seen any new outdoor/WISP hardware for a long time, mostly because with current wifi2 drivers it would be a complete joke, can’t even make a transparent link with it.
Long time ago amount of control, customization options and tools for WIFI were main reasons for buying Mikrotik WISP products, but that’s long gone.
There is really no advantage to getting Mikrotik WIFI anymore, unless you really need all in one device or for special management purposes.
Otherwise other vendors have APs that have more chains and are 2 generations ahead for pretty much same price. And configuration options are same as what you get with Mikrotik, now that you are forced to use wifi2 on new products. Yes, configuration often sucks compared to using Winbox, but if everything works, you do that only once.
So buying Mikrotik for routing, switching? YES. But for WIFI in 2023? NOPE!
Will 4-address mode (station-bridge/WDS, compatible with the older 802.11n/ac devices) be implemented with the new wifiwave2 drivers? Or is it no longer supported by the new chips?
Some nice new integrated outdoor WiFi 6E radios would be welcome too.
