No NAND device found!!!
We have some Routerboard 433AH which do not have any mtd devices. cat /proc/mtd does not show any device and boot logs are as follows:
RouterBOOT booter 3.18
RouterBoard 433AH
CPU frequency: 680 MHz
Memory size: 128 MiB
NAND size: 128 MiB
Press any key within 2 seconds to enter setup..
loading kernel from nand… kernel not found
trying dhcp protocol… OK
resolved mac address 3C:97:0E:EA:D1:B0
Gateway: 10.107.48.210
transfer started … transfer ok, time=2.42s
setting up elf image… OK
jumping to kernel code
Linux version 2.6.32.10 (sudesh@sudesh-Inspiron-1525) (gcc version 4.3.3 (GCC) ) #2 Mon Mar 10 17:58:21 IST 204
bootconsole [early0] enabled
CPU revision is: 00019374 (MIPS 24Kc)
Atheros AR7161 rev 2, CPU:680.000 MHz, AHB:170.000 MHz, DDR:340.000 MHz
Determined physical RAM map:
memory: 08000000 @ 00000000 (usable)
User-defined physical RAM map:
Initrd not found or empty - disabling initrd
Zone PFN ranges:
Normal 0x00000000 → 0x00008000
Movable zone start PFN for each node
early_node_map[1] active PFN ranges
0: 0x00000000 → 0x00008000
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512
Kernel command line: rootfstype=squashfs,yaffs,jffs2 noinitrd console=ttyS0,115200 console=ttyS0,115200 parts=6
PID hash table entries: 512 (order: -1, 2048 bytes)
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
Writing ErrCtl register=00000000
Readback ErrCtl register=00000000
Memory: 125524k/131072k available (2022k kernel code, 5376k reserved, 385k data, 1344k init, 0k highmem)
SLUB: Genslabs=7, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Hierarchical RCU implementation.
NR_IRQS:56
Calibrating delay loop… 452.19 BogoMIPS (lpj=2260992)
Mount-cache hash table entries: 512
NET: Registered protocol family 16
MIPS: machine is MikroTik RouterBOARD 433/AH
registering PCI controller with io_map_base unset
bio: create slab at 0
pci 0000:00:00.0: PME# supported from D0 D1 D2 D3hot
pci 0000:00:00.0: PME# disabled
PCI: mapping irq 50 to pin1@0000:00:14.0
Switching to clocksource MIPS
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP reno registered
squashfs: version 4.0 (2009/01/31) Phillip Lougher
Registering mini_fo version $Id$
JFFS2 version 2.2. (NAND) (SUMMARY) �© 2001-2006 Red Hat, Inc.
yaffs Mar 10 2014 17:22:48 Installing.
msgmni has been set to 245
io scheduler noop registered
io scheduler deadline registered (default)
Serial: 8250/16550 driver, 1 ports, IRQ sharing disabled
serial8250.0: ttyS0 at MMIO 0x18020000 (irq = 11) is a 16550A
console [ttyS0] enabled, bootconsole disabled
NAND flash driver for RouterBoard 4xx series version 0.1.10
NAND SPI clock 28333 kHz (AHB 170000 kHz / 6)
FLASH SPI clock 28333 kHz (AHB 170000 kHz / 6)
Atheros AR71xx SPI Controller driver version 0.2.4
ag71xx_mdio: probed
eth0: Atheros AG71xx at 0xba000000, irq 5
eth1: Atheros AG71xx at 0xb9000000, irq 4
Atheros AR71xx hardware watchdog driver version 0.1.0
TCP westwood registered
NET: Registered protocol family 17
802.1Q VLAN Support v1.8 Ben Greear <greearb@candelatech.com>
All bugs added by David S. Miller <davem@redhat.com>
Freeing unused kernel memory: 1344k freed
gpio-buttons driver version 0.1.2
input: gpio-buttons as /devices/platform/gpio-buttons/input/input0
Button Hotplug driver version 0.3.1
  • preinit -
    Registered led device: rb4xx:yellow:user
    Press the [f] key and hit [enter] to enter failsafe mode
    eth0: link up (100Mbps/Full duplex)
  • regular preinit -
  • init -
Please press Enter to activate this console. eth0: link down
device eth0 entered promiscuous mode
eth1: link up (100Mbps/Full duplex)
Generic kernel compatibility enabled based on linux-next next-20100113
cfg80211: Calling CRDA to update world regulatory domain
PCI: Enabling device 0000:00:14.0 (0000 → 0002)
ath5k 0000:00:14.0: registered as ‘phy0’
br-lan: port 1(eth0) entering forwarding state
cfg80211: World regulatory domain updated:
(start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
(2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
(2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
(2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
(5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
(5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
ath5k phy0: Atheros AR5414 chip found (MAC: 0xa5, PHY: 0x61)
cfg80211: Calling CRDA for country: US
cfg80211: Regulatory domain changed to country: US
(2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2700 mBm)
(5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 1700 mBm)
(5250000 KHz - 5330000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
(5490000 KHz - 5600000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
(5650000 KHz - 5710000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
(5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 3000 mBm)
PPP generic driver version 2.4.2
ip_tables: (C) 2000-2006 Netfilter Core Team
NET: Registered protocol family 24
nf_conntrack version 0.5.0 (1985 buckets, 7940 max)
I think you will have to replace them and send these to warranty repair. I don’t see how forum users can help in this case.
