No NAT with routing marks
Hi Guys,
Completely lost as to what I’m doing wrong here. I have 2 PPPoE connections, prima and seconda. What I want to do is:
-Connections initiated from internal network route through prima
-Connections initiated from prima route through prima
-Connections initiated from seconda route through seconda
But when I set up routing with routing marks, NAT doesn’t work anymore for some reason. Any pointers as to what I’m doing wrong?
Relevant config:
add l2mtu=1586 name="Guest LAN Bridge"
add l2mtu=1590 name="Hotspot DMZ Bridge"
add l2mtu=1586 name="Office LAN Bridge"
set 0 disabled=yes name="Port 1 WAN"
set 1 name="Port 2 Radius Server Port"
set 2 name="Port 3 To AT Switch"
set 3 name="Port 4 PPPoE WAN"
set 4 name="Port 5 PPPoE WAN 2"
/interface pppoe-client
add disabled=no interface="Port 4 PPPoE WAN" name="PPPoE WAN prima" password=\
    xxxxxxxx user=xxxx1@isp.net
add disabled=no interface="Port 5 PPPoE WAN 2" name="PPPoE WAN seconda" \
    password=xxxxxxxx user=user=xxxx1@isp.net
/interface vlan
add interface="Port 3 To AT Switch" l2mtu=1586 name="Guest LAN" vlan-id=3
add interface="Port 3 To AT Switch" l2mtu=1586 name="Office LAN" vlan-id=1
add address=192.168.253.254/24 interface="Hotspot DMZ Bridge" network=\
    192.168.253.0
add address=192.168.254.254/24 interface="Office LAN Bridge" network=\
    192.168.254.0
add address=192.168.251.1/24 interface="Guest LAN Bridge" network=\
    192.168.251.0
add action=drop chain=input comment="Traffic to router" connection-state=\
    invalid
add chain=input connection-state=established
add chain=input connection-state=related
add chain=input comment="Administration from local LAN" in-interface=\
    "Office LAN Bridge" src-address=192.168.254.0/24
add action=drop chain=input comment="And drop everything else"
add action=drop chain=forward comment="Routed Traffic" connection-state=\
    invalid
add chain=forward connection-state=established
add chain=forward connection-state=related
add chain=forward comment="Accept traffic from internal networks" \
    in-interface="Office LAN Bridge"
add chain=forward in-interface="Guest LAN Bridge" out-interface=\
    "PPPoE WAN prima"
add chain=forward in-interface="Hotspot DMZ Bridge" out-interface=\
    "PPPoE WAN prima"
add action=drop chain=forward comment="And throw out everything else"
/ip firewall mangle
add action=mark-connection chain=prerouting comment=\
    "Routing mark for connections originating from internet connection prima" \
    connection-state=new in-interface="PPPoE WAN prima" new-connection-mark=\
    prima
    "Packet marks for connections originating locally" connection-state=new \
    in-interface="Guest LAN Bridge" new-connection-mark=prima
add action=mark-connection chain=prerouting connection-state=new \
    in-interface="Hotspot DMZ Bridge" new-connection-mark=prima
    in-interface="Office LAN Bridge" new-connection-mark=prima
add action=mark-routing chain=prerouting connection-mark=prima \
    new-routing-mark=prima-route passthrough=no
add action=mark-routing chain=prerouting comment=\
    "Catch all for packets with no connection mark - default to prima" \
    connection-mark=no-mark new-routing-mark=prima-route passthrough=no
add action=mark-connection chain=prerouting comment="Packet marks for connecti\
    ons originating from internet connection seconda" connection-state=new \
    in-interface="PPPoE WAN seconda" new-connection-mark=seconda
add action=mark-routing chain=prerouting connection-mark=seconda \
    new-routing-mark=seconda-route passthrough=no
add action=masquerade chain=srcnat comment="NAT traffic on WAN interface" \
    out-interface="PPPoE WAN prima"
    out-interface="PPPoE WAN seconda"
add distance=1 gateway="PPPoE WAN prima" routing-mark=prima-route scope=\
    255
add distance=1 gateway="PPPoE WAN seconda" routing-mark=seconda-route scope=\
    255
add distance=1 gateway="PPPoE WAN prima" scope=255
What do you exactly mean by “NAT does not work”?
Is the RouterBoard used for DNS? If so you should also allow port 53 from the Guest and Hotspot network on your input chain.
I don’t use hotspot for the guest network, it’s just a WIFI network firewalled off from everything but the internet. And the routerboard does not do DNS. And “Hotspot DMZ” is actually just a DMZ for our public facing RADIUS server (yeah, wasn’t my idea…)
What I mean by “NAT doesn’t work” is that packets go out to the internet with their RFC1918 addresses as their source (instead of their route-able public IP), so nothing works.
if you set out interfaces for NAT rules, that should be enough to nat everything, however you have to ensure that incoming connection on WAN interfaces goes out the same interface it came in, so you have to mark these connections and packets with specific mark, to force them out the same way they came in.
Apparently not. I made this config with only one interface, in an x86 VM. NAT doesn’t work… if I take the routing mark off, it goes.
> # aug/14/2013 09:47:57 by RouterOS 6.2
 # software id = A1GI-IAU3
 set 0 name=ether1_LAN speed=1Gbps
 set 1 name=ether2_WAN speed=1Gbps
 set 2 speed=1Gbps
 /ip hotspot user profile
 set [ find default=yes ] idle-timeout=none keepalive-timeout=2m \
     mac-cookie-timeout=3d
 add name=dhcp_pool1 ranges=192.168.1.100-192.168.1.200
 add address-pool=dhcp_pool1 disabled=no interface=ether1_LAN name=dhcp1
 /tool user-manager customer
 add backup-allowed=yes disabled=no login=admin password="" \
     paypal-accept-pending=no paypal-allowed=no paypal-secure-response=no \
     permissions=owner signup-allowed=no time-zone=-00:00
 add address=192.168.1.254/24 interface=ether1_LAN network=192.168.1.0
 /ip dhcp-client
 add add-default-route=no dhcp-options=hostname,clientid disabled=no
 interface=\
     ether2_WAN
 add address=192.168.1.0/24 dns-server=192.168.1.254 gateway=192.168.1.254
 set allow-remote-requests=yes
 /ip firewall mangle
 add action=mark-routing chain=prerouting new-routing-mark=test
 add action=masquerade chain=srcnat out-interface=ether2_WAN to-addresses=\
     10.1.2.1
 add distance=1 gateway=192.168.90.254 routing-mark=test
 /system identity
 set name=CPE
 /system lcd
 set contrast=0 enabled=no port=parallel type=24x4
 /system lcd page
 set time disabled=yes display-time=5s
 set resources disabled=yes display-time=5s
 set uptime disabled=yes display-time=5s
 set packets disabled=yes display-time=5s
 set bits disabled=yes display-time=5s
 set version disabled=yes display-time=5s
 set identity disabled=yes display-time=5s
 set ether1_LAN disabled=yes display-time=5s
 set ether2_WAN disabled=yes display-time=5s
 set ether3 disabled=yes display-time=5s
when configuration is not working, can you give us output of ‘/ip route print’ and ‘/ip address print’
[admin@CPE] > ip route print
 0 A S  0.0.0.0/0                          192.168.90.254            1
 1 ADC  192.168.1.0/24     192.168.1.254   ether1_LAN                0
 2 ADC  192.168.90.0/24    192.168.90.114  ether2_WAN                0
[admin@CPE] > /ip address print
 #   ADDRESS            NETWORK         INTERFACE
 0   192.168.1.254/24   192.168.1.0     ether1_LAN
 1 D 192.168.90.114/24  192.168.90.0    ether2_WAN
