One small annoyance I always encounter with upgrading to a new version is having to then re-install the ntp package to run an ntp client. It is particularly annoying to have no ntp client where the clock resets on every boot…
I thought it used to be included in the combined package however it seems now. Is there any chance you can incorporate at least the client into the combined package?
if you need time for router, SNTP is good enough, it is less precise and uses way less resources when compared to NTP client that is provided by ntp package.
If you want to run NTP server on the router, then SNTP won’t cut it.
Sorry, I’ve searched a lot for the NTP package and couldn’t find it… I’ve RB1100 with RouterOS 5.12 and I can’t see the NTP package at the Package List, neither at the download section of the site.
I know this is a 1 year old thread but same problem here
