NO PWR LED indicator RB750g
Mik Fans
I got 2 RB750G with no LED PWR indicator.
Reason: The limiting resistor of the PWR LED was dislodge from the placement area between LD301 and LD302. I think this is a cold solder when resistor is heating up.
With luck, i saw the resistor stuck on the rubber pad near the reset hole(not the tact reset but the PCB circle area).
I checked the value and its 133 Ohms (maybe tolerance issue of my resistance tester). Mik guys, please confirm if my value is correct so I can change the other unit with the same issue(can’t find the resistor of the other unit). I’ll post the pic when I get my USB cable.
Two units are working..just the PWR indicator.
Hope this can guide you improve your manufacturing process.
wirelessguy
actually the value should be 75ohm, but 133 should also be ok.
