Hi there folks,
anyone experiencing reboot issues with RB493AH with RouterOS 3.2x ?
Actually - I only noticed it when the watchdog was rebooting the box due to non availability of a remote system.
It just reboots - then is stuck on the boot-menu.
Even if I tell it to reboot manually - connected through Serial Console to a linux box - however nothing is running on the serial terminal except when I connect to it using minicom - I see the messag where I have 2 Seconds to go to the boot menu - and then it jumpts into the boot menu anyway and waits.
Anyone has a hint on what to do ? It’s kind of stupid if I’m away and have to ask “non-admin” people to go through the process to connect with minicom etc. and that box over the phone).
Booting is configured to go from NAND then from Ethernet. However - nothing to do.
smurphy@gw-sollan-RB493AH] /system routerboard> print
routerboard: yes
model: "493AH"
serial-number: "XXXXXXXXXXXXXXX"
current-firmware: "2.20"
upgrade-firmware: "2.20"
[smurphy@gw-sollan-RB493AH] /system> watchdog print
watch-address: XXX.XXX.XXX.XXX
watchdog-timer: yes
no-ping-delay: 5m
automatic-supout: yes
auto-send-supout: no
and
[smurphy@gw-sollan-RB493AH] /system routerboard settings> print
baud-rate: 115200
boot-delay: 2s
boot-device: nand-if-fail-then-ethernet
enter-setup-on: any-key
cpu-frequency: 680MHz
boot-protocol: bootp
enable-jumper-reset: yes
force-backup-booter: no
