I own a RB1100 running my SoHo network.
For power protection I use an APC Smart-UPS SC 450VA 230V.
The RB1100 and APC are connected with the serial cable as supplied by APC.
When I reboot (soft or hard) the router with the serial cable connected, the reboot process hangs.
If I reboot when the serial cable is disconnected, everything works normally.
I have not many reasons to reboot the router
but it is a bit anoying when doing a remote upgrade of the RouterOS ![]()
Does anyone have the same problem and even better a solution for this?
TT
