I have set up a Mikrotik CRS326 24 ports with RouterOS, I was expecting to get an IP address when plugged in ether2 but I see no DHCP response coming out of the switch.
Any idea what’s preventing the responses from making it to the device?
Export is available here: http://ix.io/3QEA
copied below
# feb/24/2022 19:17:24 by RouterOS 6.49.1
# software id =
add name=bridge vlan-filtering=yes
set [ find default-name=ether1 ] disable-running-check=no
set [ find default-name=ether2 ] disable-running-check=no
set [ find default-name=ether3 ] disable-running-check=no
set [ find default-name=ether4 ] disable-running-check=no
set [ find default-name=ether5 ] disable-running-check=no
set [ find default-name=ether6 ] disable-running-check=no
set [ find default-name=ether7 ] disable-running-check=no
set [ find default-name=ether8 ] disable-running-check=no
set [ find default-name=ether9 ] disable-running-check=no
set [ find default-name=ether10 ] disable-running-check=no
set [ find default-name=ether11 ] disable-running-check=no
set [ find default-name=ether12 ] disable-running-check=no
set [ find default-name=ether13 ] disable-running-check=no
set [ find default-name=ether14 ] disable-running-check=no
set [ find default-name=ether15 ] disable-running-check=no
set [ find default-name=ether16 ] disable-running-check=no
set [ find default-name=ether17 ] disable-running-check=no
set [ find default-name=ether18 ] disable-running-check=no
set [ find default-name=ether19 ] disable-running-check=no
set [ find default-name=ether20 ] disable-running-check=no
set [ find default-name=ether21 ] disable-running-check=no
set [ find default-name=ether22 ] disable-running-check=no
set [ find default-name=ether23 ] disable-running-check=no
set [ find default-name=ether24 ] disable-running-check=no
/interface vlan
add interface=bridge name=LAB vlan-id=220
add interface=bridge name=MGMT vlan-id=99
add name=dhcp_pool0 ranges=10.220.2.2-10.220.2.254
add address-pool=dhcp_pool0 disabled=no interface=LAB name=dhcp1
add bridge=bridge interface=ether1
add bridge=bridge interface=ether2 pvid=220
add bridge=bridge interface=ether3
add bridge=bridge interface=ether4
add bridge=bridge interface=ether5
add bridge=bridge interface=ether6
add bridge=bridge interface=ether7
add bridge=bridge interface=ether8
add bridge=bridge interface=ether9
add bridge=bridge interface=ether10
add bridge=bridge interface=ether11
add bridge=bridge interface=ether12
add bridge=bridge interface=ether13
add bridge=bridge interface=ether14
add bridge=bridge interface=ether15
add bridge=bridge interface=ether16
add bridge=bridge interface=ether17
add bridge=bridge interface=ether18
add bridge=bridge interface=ether19
add bridge=bridge interface=ether20
add bridge=bridge interface=ether21
add bridge=bridge interface=ether22
add bridge=bridge interface=ether23
add bridge=bridge interface=ether24 pvid=99
/interface bridge vlan
add bridge=bridge tagged=bridge,ether23 untagged=ether24 vlan-ids=99
add address=10.99.1.1/16 interface=MGMT network=10.99.0.0
add address=10.220.1.1/16 interface=LAB network=10.220.0.0
add address=10.220.0.0/16 gateway=10.220.1.1
